The fact that I still can't get this stupid boost controller to work properly. I'm ready to just up and buy a different one, although if I did that I'm sure Allen would kick my ass :)
wgmg hayfever
that is all
+10000000000000
wgmg people who drive in the right lane just because they can... honestly F**K OFF!!!!
i rekon ill get a knock on the door from police coz i think about 4 randoms i cut infront of reported me.
This has probably been mentioned a thousand times, but people that give me shit for having a non-turbo. Joking around doesn't bug me, but some people say it as if it offends them that i own it... Im 18, my car is faster than other cars, your car is faster than my car, and GTR's are faster than your car, clearly someone is always going to have a faster car than you, so fuck off :P
wgmg, you cant rely on a lot of people these days!
TIP-if you know a lot about cars and know how to fix them, do yourself a favour and do most of the work yourself. one day i left my car idling, i heard a rattling noise from the undercarriage, thinkin it was gearbox, jacked the car up and found one of the exhaust bolts loose cuz da nuts come off! i had a workshop which ill keep anonymous fit my new dump/front pipe at the start of the year cuz i was lazy to fit it myself. so, if you can carry out some of the jobs yourself, do it but if your not confident, be sure to send it to someone you can trust your ride with.
WGMG people who've never seen under the bonnet of their car. Agreeing with your tip - do as much work on your own car as you can!
Also WGMG, tired and cranky bitch-arse girlfriends who kick their boyfriends out of bed because he's trying to beat the lap record of Tsukuba Circuit in a Spoon Fit race car.
Bitches be running wild up in here... pity it's not the kind of wild it used to be. WGMG - relationships that require waaaay too much effort.
  • 4 weeks later...
Living right next to a nice beach on summer days with lovely weather really grinds my gears
I have been listening to that creepy warped electronic pied piper child rapist icecream van song pretty much all day every day and I am looking forward to yet another weekend of it.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
