Hey all,
I've had my R32 GTS-T for a while now, and as a daily driver it's been left pretty much stock in the engine department (3 inch cat back and K&N pod is all). Don't get me wrong, I love the RB20, but for a car that very rarely sees above 4500 rpms in daily usage (commuting to work etc.), I'm starting to feel the pain of a lack of sub-3000rpm pull. What I want is more torque!!!
I figure futher intake and exhaust mods will get the turbo spooling quicker, but I am not sure I will get the results I am looking for from an internally stock RB20DET. So I was thinking maybe high compression pisons (2.0 litres), a stroker kit (2.2 or 2.4 litres), an internally standard RB25DET swap or a high compression RB30DET build. I figure it could be done RELATIVELY cheaply seeming I am only after low RPM gains, rather than big top end gains. A peak of 200-220rwhp would be satisfactory (although any more would be nice :) ), but strong torque everywhere is what I really want!. I'm not trying to tow a combine harvester, and I'm not chasing Corvette LS7 engine levels of stump pulling sub-3000rpm grunt. Something closer to a healthy manual ECOTEC VT Commo or similar at sub-3000rpms (no flaming for that comment!).
Only kicking around some ideas at the moment, and was wondering if anyone had some suggestions or input. Or critisism. Or pwnage. Or whatever. I just want torque without going overkill on the engine build!
:O And no suggesting a 3.8L ECOTEC conversion. My ECOTEC ute driving brother has already suggested that. :O
Edited by Big Rizza
https://www.sau.com.au/forums/topic/116190-my-quest-for-torque/
obviously a capacity increase if what you need.
So its RB25, RB30et or RB30DET
And all of those have been covered to death :)
Set your budget, and pick whichever falls into it really
An RB30et will put 150rwkw on a stock turbo.
Engine + ECU etc can be had for 2k
Hmmm... for some reason I hadn't considered the RB30et, and only thought of an RB30DET build. The RB30et would certainly satisfy all criteria I have laid down i.e. more torque with no loss of top end power. Cheers!
But a commodore engine in a skyline? :)
Edited by Big Rizza
2.4ltr stroker kit, provide u with a lot more talk, not too hard to achieve either.....well to 2.3 anyway
GTR crank and rods, and maybe pistons too for the hell of it, changing to a RB25 or sumthing like that is a good solution, but y not crank ur current engine
if i was in this situation, i doubt i would swap in an RB30ET. i feel as if this is a down grade in engine. sure you get your torque and all the rest, but it just wouldnt sit right with me. the way i would go about it would probably be a 2.4L stroker kit and possibly a bolt on turbo, maybe a GT2530 or KKR 330?. (as well supporting mods) or even with out the stroker, go for something like the GT2510 or something small that will kick in pretty early in the rev range. give you some much needed low-mid range power/torque. the 2510 will make 200rwkw (more or less depending on variables) which the RB20 will make with stock injectors or at least 440cc/min.
just a final thought that i will probably get FLAMMED HARD CORE for this seeing that it is a toyota and this is a nissan forum, but ever thought of the 1JZ? very similar engine to the RB26. cheaper, no hassle of swaping the RB26 into RWD mode?
just some food for thought.
good luck with you decision
brendan
try http://www.skylinesaustralia.com/forums/in...howtopic=103095 for more ideas, with out stroking
Edited by NMD
The RB25 with better flowing 4 valve cylinder head and high static compression ratio of 9.0:1 makes up for the 500cc it lacks compared to a factory RB30ET, which is only 2 valve and a 7.8:1 static compression ratio.
Either bolt in a complete RB25DET or throw an RB25 cylinder head onto a wrecker RB30 and enjoy the torque wave!
Should be able to easily do both for $3K if you are handy with the tools.
Not sayign you are wrong...but can you do some quick numbers to show how it can be done for 3k (RB30) I havce a gut feel that those about to do it say 3k, but most ppl who do it will tell you its costs more?!?!?!?!
It does cost more then 3k. people are spending more money then that on bottom ends. I got mine done really cheap 3 years ago nearly and it cost me about 4.5k (mates rates) and i used standard cast pistons.
1) you want to stroke the motor, then put a larger turbo onto it?
Its kinda pointless. You'd want to leave the stock turbo on there.
2) Converting an RB26 to RWD? What you mean? Its a simple case of bolting it to a gearbox.
I've certainly have no hassle, neither have the other countless people.
Also to think about is the layout of the 1jz... its opposite to an RB :D
So in effect, its more hassle as you have to have custom exhaust piping made, etc etc etc etc etc.
I cant see how you can pass that off as a "less hassle" alternative
Modded 26 sump... i wouldnt call it a "hassle" when you drop it off and get it back a couple days later
certainly easier (cheaper) than getting an exhaust re-routed to suit a motor that is opposite to what a car is desienged for :D
sequential turbo setup! nos! cams! lightened flywheel! weight reduction!
er... just get an rb25..
by the time you dick with everything the rb25 is the laziest solution for torque and response.. the rb26 lazier still.. just more initial outlay.
it doesn't cost much if you can do the work yourself. If you can lift out an rb20 you can lift *in* an rb25 just as easily. It just requires a bit of faith in the engine. Buy one off some kid who stacked his non-insured r33 for instance, that was driving around fine 2 weeks before.
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
