wierd... expensive tho $550 to get a 'tag lock down system' installed...
interesting idea tho... wonder how it works with AWD... and the weight/aero part of it?
what the fark is with that gay video of those girls dancing around??!?
Also:
"With a racing membership, each vehicle is set up in Drag Tag’s workshop where it is weighed, and the frontal area and drag coefficient from the car's manufacturer entered into a computer. Using this information, we are able to assign a carefully-calculated air resistance equation."
Haven't had my car on it mate...would love to though.
From what I've seen, the results are incredibly accurate compared to others' real-world drag times.
I need to find the photos of the Linux arrays running the thing. The number crunching is in-farking-sane!
Adrian
Adrian, are you affiliated in any way with Drag Tag? Just would like to know if the opinion is unbiased.
Without airflow how is the engine, brakes, etc. cooled?
With 4wd cars how can you turn the wheel? As i have seen some close calls if the wheels are not kept straight.
yeh i notice that in the pics aswell, no fans or anything
I've been exposed to it and its development in various ways for a couple of years. I don't work for them and they're interstate! :O My employer has advertising at their premises and vice versa.
It's just a cool concept. Skip the drag racing component for a sec and think of the driver training aspect. Controlled environment driver education in real world situations. Great idea with heaps of promise.
I support any idea that increases driver training and road safety and gets the fast cars racing where they should be.
Brake cooling etc..... dunno. I'd send em an email. Every question I've ever asked has been answered promptly and sensibly.
Adrian
I've been exposed to it and its development in various ways for a couple of years. I don't work for them and they're interstate! :angry: My employer has advertising at their premises and vice versa.
Adrian
Great.............
Would be good to get some answers. For 2wds the front brakes wont matter as they are stationary, but the rears may get a little warm :D.
The concept is great, hopefully it kicks off for them.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
