steamed or fried?
steamed is good coz they soak up the soy sauce...but fried are good coz they're fried....a combination of the 2 would be ideal, but then you'd have to purchase 4 so that you didnt regret having 2 of 1 and 1 of the other...
steamed or fried?
Ahahahahaha
So True!!!
this fish n chip shop across the road from my gf's house sells souvlakis for $4! ill have to check out their dim sim price next time im in there, and maybe we can organise a group buy.
2 of the guys there have skylines too..white 32 gts4 (i think) and a s1 burgundy 33....they'll be sure to give us a good price
I went to somewhere for lunch today and dim sims were $1.20. And then on top you had to pay for a little sachel of soya sauce.
I used to get 3 dimmies with sauce for a $1 a school. When's it all going to stop!!?
Were they "normal" ones or the Sth Melb Market ones.
Sth Melb Market ones i'd pay $1.20 for as they are nearly triple the size of your average joe.
But if not, thats a RIP!!!!!
FYI - to buy the dimmies yourself costs around .30c if you go to a wholesaler, so god know what the stores pricing is like, probably even cheaper
hahaha ash.. you've got a death wish! (same with the rest of you :thumbsup:)
I used to work across the street and my workmate used to go there all the time..
Can't find the article from the Herald but...
7 Jun 2004 "fined $30,000 for unsanitary work practices"
...pleaded guilty to failing to keep its premises in a clean and sanitary condition and failing to protect food from contamination during transport.....
PEC Pacific Holdings Pty Ltd owners Edward and Phillip Cheng pleaded guilty to 11 offences under the Food Act and for breaches of the Australian food safety standards.
YUM!
I think I read a while back that there was a plan to nationally boycott the Multinational Dimmy companies.
Emails were flying around requesting that on one scheduled day, nobody would buy them, but it never came to fruition. It was just impossible to organise, given its such an in demand commodity. What we need is the govt to cut the excise on dim sims :thumbsup:
3 dimmies AND soy sauce for a dollar was pretty sweet andrew...
when i was at school they were 50cents a pop... and soy sauce was free too
but you know what was really cool at the canteen? Assorted lolly bags!! 50cents each and you got everything!!!...
just thinking about them makes me want to go down to bilo to get some sugar...
hahaha ash.. you've got a death wish! (same with the rest of you :))
YUM!
If people get sick from food like dimmies, which are predominately cat and dog anyhow...
They just need a can of HTFU - Harden The F*ck Up :):P
Emails were flying around requesting that on one scheduled day, nobody would buy them, but it never came to fruition. It was just impossible to organise, given its such an in demand commodity. What we need is the govt to cut the excise on dim sims :P
Yeah it's a good start for sure, but those in the know have heard whispers that any excise cuts would be minimal and offset by an across the board retail price increase anyway. The govt are part of the whole conspiracy and happily dance to the tune of their puppet masters...the Vietnamese & Chinese dim-sim cartels!.
Sadly if you want to run with the big boys and have the best gear you'll have to pay whatever premium these leecherous cartels decide :)
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
