Yo!
If I get someone to convert my auto R33 to a 5SPD Manual one, would it go much harder? would I gain the lost KW that auto transmission loses through the drivetrain?
Once converted, would I be able to use Apexi Power FC and all that stuff ???
Would it drive and feel like a proper manual?
Is it worth Converting if I want to turn my car into a animal??!?
Thanks
Yo!
Thanks
mate it depends on wat ur guna do with the car.. drag, drift or a streeter... drag= tuff auto, drift=manual, streeter = wateva ur comfortable driving
if you convert an auto to a manual it will run perfect if done right. You can use a power fc and everything like that. You can have a tough street/drag/drift car with a manual also have a tough drag/street car with auto. With a skyline i would personally use a manual, way better than autos also alot more fun to drive.
Why did you buy an auto if you wanted a manual?
I agree with WazR32GTSt.
Just trick the auto up with a shift kit and put a decent cooler on it.
The $2.5k you can spend on getting a manual box fitted, could be spent on the engine. General cost to do a conversion(box+labour) is $1500 - $4700 depends on the mechanic and who you know etc etc.
I already looked into this sorta stuff before I bought my car. You would've been betteroff if you just bought yourself a manual in the firstplace.
If want to get back those kw you lose through the auto, spend the money on your motor....
Edited by KeyMakeR33
Here are a few things you will need;
Gearbox
Gearbox crossmember
Tailshaft
pedal assembley
clutch master cylinder
clutch slave cylinder
clutch
flywheel
bell housing
center console
dash cluster
computer
some fluid lines
manual spigot bush
It all adds up plus labour, I thought about doing it but in the end I thought about $2500 on an auto rebuild would make it go harder then most manuals (with the same power of course) in a straight line. So if it is only straight line speed you want then Automatics are easier and change faster therefore loosing lees boost :thumbsup: . I have also heard with a manual valve body on your transmission then you can put a PFC on it because it changes gears by itself not the computer.
I also just bought a Davis Craig ATF cooler off of AlexCim in his group buy, I will be installing on the weekend.
http://www.skylinesaustralia.com/forums/in...howtopic=111628
Chris
It's easy to do yourself once you know the procedures for each component such as aligning the clutch, spigot bearing, and bleeding the clutch. The rest is bolting it up.
I've never done a manual conversion before. Did it in my garage and all is working well.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
