Hey all,
Just wondering if the usually black bottom lip or spoiler that comes on the R34 GTRs are avaliable directly from Nissan or perhaps anywhere else? Curious to how much it cost if it is avalible, does anybody have the part number?
I've attached pictures to show you the part I mean, the red line highlights the part I'm talking about.
Thanks guys,
Andy
I'm sure you can get them from nissan new, as to how much not sure, I can tell you the same part on an R33 GTR (that lower lip) costs around 900-1300 new from nissan..... so don't expect the R34 GTR one to be cheap....
R34 GTR's have a lip like the 33's but V-specs , M-specs and NUR-specs have an extra lower lip that goes under the car as well , i think thats the one he is talking about. They are not cheap, ring your local Nissan dealer to find out a price.
The lip in this pic has the top lip attached to it, the top part of it only comes in the standard GTR's the bottom ( big one) is in adition to the top part in the V-specs.
34_lip.doc
The R34 GTR has a front lip which attaches to the Front Bumper Bar.
V-Spec's (and all subsequent variants) and M-Spec's have an additional Front Diffuser which is the part you have pointed out. These are around the $1200 mark new from Nissan. They run under the front of the car and cover the sump and so on. It's not just a plastic strip.
I think I'm after the V-spec bottom lip - it goes around the whole bumper and in the middle its blank except for too connecting rods/poles.
Gee thats a hefty price tag! Might try to get just the lip part made up and see how much that'll cost.
  • 4 months later...
This is a bit of a old thread, but still useful info
Front diffusser R34 GTR V -spec
Part number 75890-AA410
$1229.10 trade price
The matching engine under tray
Part number 75880-AA410
$800.40
The lip is the last bit I need to get for my R34 GTR front conversion on my Stagea
Can we please get confirmation on this - as Nissan have given me conflicting part numbers.
They have quoted me:
Front Spoiler 96015-AA440 - $1279.58
Front Diffuser 75890-AA410 - $1407.50
This is the part im after (as TNT farked mine putting the car on the truck) - attached below (just want confirmation on what is the correct part number)
Daniel
$800.40 trade price
Approx same price
Hey all,
Thanks guys,
Andy
This is what you need if you still have your Aero style front bar, East Bear Aero lower lip.
nah the east bear one look ugly...nyways try saking top secret abiut it...they have the diffuser and the lip attached together costing US $1065 mite still be cheaper than getting separate lip and diffuser...
http://www.topsecretjpn.com/diffuserpro.shtml
$800.40
*waves hand jedi style*
You dont want to bid on those parts. :)
Question is why are you looking at GTR parts for the GTT; aren't these R34GTR "specific" parts...
Don't tell me you're going to spend $1k for a piece of plastic then chop it up to fit :)
excelent as I'm bidding on them and dont want to get into a war! lol
It is interesting they quote the new price of 37,??? yen which is approx $425 and we pay over $1200 here
There normally is not that big a price difference betwwen here and JP and new parts
I do not need the engine tray, I just want the air diffuser/lip, so I will bid on one of them instead :)
Daniel
I have just had a quote back from www.japanparts.com on the front diffusser
I have used these guys before with great results
$539 part
$283 delivery 10-15 days
That's $822 compared to Nissan Aust of $1229 trade or $1407.50 retail
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
