I have about $3000 to spend on mods for my R33 GTS-T, and I am just wondering where that money is best spent. I did do a search, but I got too many threads which had nothing to do with what I am after.....
The car is basically stock except a HKS pod, and exhaust (I think it is cat-back).
I was thinking of doing one of the following (though I am open to suggestions) -
1. Power FC computer, Boost Controller, and do a dyno tune with about 8-9psi.
2. FMIC (a good one, not a cheap crap one) and boost controller, run about 10psi, but I am not sure if this will cause problems without the car being properly tuned.
I basically want to get as much power as I can, but without taking risks on reliability. I would like to get the FMIC and the Power FC, but I just don't think I have the budget for it. Should I consider using the SAFC instead - the car will not get modified much beyond the mods I have listed (around 180-200rwkw will suffice).
That $3000 also needs to include labour for fitting, tuning and whatever because I am not too familiar with Skyline engines yet, so I can't really do the work myself.
Any suggestions would be most appreciated.
Edited by Quinny
https://www.sau.com.au/forums/topic/118256-best-bang-for-your-bucks/
  • Replies 138
Posted Images
coverd many timmes. But, one of those 400$ gtek fmic kits in the group buy section.
jaycar iebc - 130 including handcontroller.
finish off your exhaust - justjap/batmbl
powerfc + Tune
mate i used to be a manager at jaycar, im also an electronics engineer, and i can only say, unless your electronically minded and have had experience in doing this, DONT. f**k it and the kits useless.. by a gated tee, much cheaper and less headaches... or save more and buy a nice eboost
I don't really know too much about turbo engines (V8s on the other hand...) so I will be leaving the fitting, tuning etc of everything in the hands of professionals. I want an electronic boost controller rather than a manual one. If I get the Power FC, I will get the boost controller kit with that.
PFC, boost kit, split dump exhaust, fmic
should get a few $ change from 3000 not much tho
Really? The way I work it out, the PFC cost about $1100, PFC boost controller $400, Tuning $500, that is $2000 just there. I don't think I would get a FMIC + fitting, and exhaust for $1000.....
I might let the dyno decide. I will do a run before I do any mods and see how the AFRs and power curve looks, if they look ok, then the FMIC will be the go, if they look a bit dodgy, then the PFC might be a better choice.
One question about the PFC, can I get the factory fuel cuts and things like that removed or changed with the PFC? Will the factory fuel cuts cause any problems with extra boost if I run the stock ECU?
Edited by Quinny
pfc - $960
batmbl split dump + hi flow cat - $700max
fmic $400 - GKTech Group buy
tune - $500
pfc - $960
tune - $500
Where can you get the PFC for $960?
I also need to add a boost controller and fitting of the FMIC to the list.
Are the $400 coolers any good, do they come with piping etc?
If you want an ebc the pfc boost kit is the cheapest way out of it UNLESS you are electronically minded and able to solder the jaycar kit together.
Do remember the purchase of the jaycar kit + some one else assembling it will cost you the same if not more than a pfc ebc.
Another option is to buy an adjustable actuator from a turbo shop, they can be purchased in a variety of base boost level's then tweaked via the adjusting nut to achieve the boost level your after. They are around $130.
Or find an R32 rb20det actuator and drop that on for a 10-12psi boost level.
There is a few options, but for 3k it will be close.
- Second hand R34 GTT intercooler or $400 one in group buy section
- Forget ebc get a r32 gtst actuator and run 10psi or if you cant find one the $22 boost controller do a good enough job at this level of modification search on these forums for more info
- power FC and tune
- highflow cat and open belmouth dump if you dont have enough money left go the split dump all can be found on these forums
Reliablity wont be any be an issue if you tune your car regulary with good oils ect.
cheers
If I was to get the Power FC+Boost control and one of the GKTech coolers, then get it dyno tuned, am I likely to run into any problems? I have heard a few people mention fuel cuts etc that I don't really know much about. Is there anything else I need to know before I go and spend my money on this?
I will have a look at the exhaust as well, and see if anything needs to be done there, if I have the money, I will get it done too, if not, I will get it done later.
Also, how much power should I expect from this setup, at 10psi?
fuel cut wont be there with a powerfc...once thats in...no speed limit....no R&R...no nothing except whatever the tuner puts in. Mate if youve done alot of work on v8's...a car is a car, if you take something off just make sure you put in on the same way.
Just dont get too cosy thinking you can hang off the front quarter panels and drop your legs into the engine bay....youll be lucky if you can get your arms around half the shit in there. If you get stuck...its just a matter of jumping on sau and asking for help....more then enough people on here to offer it.
Power..well depends what dyno and how it reads...but im guessing around 180rwkw's. Some people have probably made more..and some have probably made less. When i had only those mods on my car except i had pfc ebc...on 12psi mine only made 170 odd rwks.
Edited by r33_racer
Thanks r33_racer, I wanted to confirm the PFC wouldn't have any of those problems. I was also planning on using the PFC boost control, but I hope I get more than 170rwkw, but if not, I will get over it. I am more interested in strip times (mid - low 13 sounds good).
I think I may have it sorted, GKTech cooler, PFC+Boost Controller, dyno tune....
If your exhaust is only a cat back be sure to install a dump/front and a highflow cat
cheers
I plan to get the exhaust done as well - at the moment I am not sure what setup it has (it was like that when I bought the car). I figure that I am better off to get the tune, cooler, computer now, and finish the exhaust later (and get the tune re-done if I have to) than do the exhaust now, and get the tune and computer done later.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
