  • 3 weeks later...
  • Replies 138
Posted Images
What do you guys reckon about this? Is this about the best way to spend my money? The parts I have chosen have been chosen because they are supposed to be the best, not necessarily the cheapest.
Apexi Power FC - $980 (Nengun)
PFC Boost Controller - $410 (Nengun)
Blitz LM Tube & Fin or ARC Turn Flow FMIC - $1200 (Nengun)
Hi-Tech Stainless Turbo Back Exhaust - $1800 (Hi-Tech Mufflers)
Dyno Tune - $500 (RUF Performance or Silverwater Auto Services)
Total $4890.
Once this is in, I am hoping for around 180-200rwkw @ 10psi, and a mid 13 quarter would be nice.
Opinions?
Edited by Quinny
Humm lets see.
1) Power FC groop buy $960
2) Full exhaust form just jap, mild steel $699
3) High flow cat eBay $200 or free if you do it yourself
4) Turbotech boos controller the $22 one
5) FMIC from just jap $499
6) 3 sets of guages form JustJap $199
7) decent filter eBay of JustJap $100
all adds up to be less then 3k
Although these are not the chepeest to, thay do the job and they do it very well. I am not into paying for brand names just for the name.
for example and Exedy clutch is about 1500, same clutch made in same factory under ACT is $400, same clutch identical.
I wanted to get decent parts, not cheap shit. The reason I wanted the Hi-Tech exhaust is because they have been proven to make 25rwkw just from exhaust, that is pretty impressive. I also want an electronic boost control rather than manual, and a decent cooler rather than a cheap one.
As I said, I chose the parts because they are the best, not necessarily the cheapest. You get what you pay for.
Also, my Exedy HD Sports clutch cost me $420...
lol..
10kw my arse.
I've had mine on the dyno running 1bar back to back with the stock airbox/panel and a K&N filter sticking up in the cool air from the fan.
There was a big fat ZERO rwkw difference from idle to peak power.
Unless its making some decent numbers (200rwkw+) the stock air box is fine.
Pods and intake mods are the worse bang for buck mod one can do on the skyline.
The real bang for buck is to concentrate in the following order.
1. Exhaust
2. Up the Boost
3. FMIC & up the boost some more.
4. PowerFC
6. Drop a nice panel filter in to your airbox
7. Bolt a bigger turbo on, then most definitely look at improving intake airflow.
I may have forgot something as I'm as tired as all buggery. :D
also dont forget the tune, it will also take a nice chunk out of that $3000..
and if your planning spending $3k then dont add up your costs to exactly $3k as i can assure you, you will need another couple hundred on top for things you havn't planned
if your exhaust is straight through, no restrictions and mandrel bend pipes, it makes FUCUK all difference. The dump pipe makes the most difference is a good exhaust system. The rest of the system, as long as it is free of sharp bends and good simple straight through design, there is nothing that can make is make any less power then a EXPENSIVE item.
Trust me I am a Mechanical engineer, and all I do every day is design airflow systems. I even designed my own exhaust system for my FWD magna, yes I know stop laughing, but my design was 1/2 the price of a GOOD exhaust system, following the same path as the stock exhaust, it is 100% legal and only 83dBA and it flows more then the so called SPORTS system.
With an exhaust you need to maximise airflow without causing the air to go turbulent too much. Turbulence = DRAG, and restrictions.
Anyway, it was just a suggestion, I am merely talking bang for your bucks.
You can get a bit more by choosing rightly.
Thanks guys, I appreciate the feedback. I am a little hesitant to use cheaper parts, because doing things by halves only causes problems. Since I did my Commodore - I spent a whole heap of money, but it just didn't work properly because I skimped on some things, I have kind of adopted a "do it right, do it once" attitude now.
Realistically, the car probably won't get much more modification than the mods listed above, but I will have to see what the budget looks like down the track.
You dont need to upgrade the computer to run 10psi
I have about $3000 to spend on mods for my R33 GTS-T, and I am just wondering where that money is best spent. I did do a search, but I got too many threads which had nothing to do with what I am after.....
The car is basically stock except a HKS pod, and exhaust (I think it is cat-back).
I was thinking of doing one of the following (though I am open to suggestions) -
1. Power FC computer, Boost Controller, and do a dyno tune with about 8-9psi.
2. FMIC (a good one, not a cheap crap one) and boost controller, run about 10psi, but I am not sure if this will cause problems without the car being properly tuned.
I basically want to get as much power as I can, but without taking risks on reliability. I would like to get the FMIC and the Power FC, but I just don't think I have the budget for it. Should I consider using the SAFC instead - the car will not get modified much beyond the mods I have listed (around 180-200rwkw will suffice).
That $3000 also needs to include labour for fitting, tuning and whatever because I am not too familiar with Skyline engines yet, so I can't really do the work myself.
Any suggestions would be most appreciated.
10psi is probably a bit boring, but I don't want to risk reliabilty for a little extra performance. From what I have seen on here, 10psi is about the safe limit for a stock turbo, maybe down the track I will get a hi-flow or a different turbo, but for now it will have to do.
The main reason for the computer is so I can get the car tuned to ensure everything remains 100% spot on.
Basically, I want to get as much extra power out of the car as i can, but without compromising on reliability. I need to ensure that I can get in and drive the car anytime, anywhere without worrying about it breaking down.
12 psi is where its at :(
Isn't 12psi really pushing the stock turbo? I don't want to push for the extra 15hp (or whatever 2psi is worth) if there is an increased risk that the turbo will fail.
If you knew my previous history with cars and the problems I have had, you mayunderstand why I want to avoid any problems with this car.
Edited by Quinny
12psi is bugger all.. 13psi is considering pushing the turbo in my book. :(
It all comes down to the tune and your driving style..
If I had the car at the track I wouldn't push an rb25det turbo past 9psi. :D
On the street I would feel happy with 12psi as on the street the driving style is little squirts, no long third gear hold outs that generate lots of heat. Heat is the killer for ceramic turbo's, detonation is very nasty for them. :D
I am thinking it is better to be safe than sorry... If I run 12psi, and the turbo fails, then the car is off the road until I can get a new one, that is what i want to avoid.
I don't think that detonation will be a problem, with an aftermarket ECU, and intercooler, detonation should be kept under control.
Edited by Quinny
3k eh?
* Just Jap stainless steel 3inch dump pipe (turbo to cat-converter) $240 delivered - ebay
* 3inch highflow cat-converter $160 delivered - ebay
* intercooler kit, with pipes $450 - ebay
* fitting at exhaust shop for intercooler and exhaust - $500 (?)
thats $1400 approx., nice free flowing exhaust and the cool air charge from new fmic
* manual bleed controller - look her on the forums, $22-$100
* Power FC and tune - rest of your hard earned :(
Tune for 11psi should be nice and 'safe'
OR - save $500 and do the fmic yourself, thats great fun and a top achievement feeling once youve got it all sorted! I had great fun doing mine, and I feel real good about having a go myself. Use that $500 for a Bosch 040 fuel pump, installed with direct wire feed to battery, might even have $ left over for a Nismo fuel pressure regulator, adjustable, off Nengun for around $160 delivered.
Good luck, thats 3k spent and a bit of fun doing so. 3grand CAN go along way. Spend it wisely and get as much as you can for your $$$.
Brendan
Edited by Tangles
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
