  • Replies 403
Hi Guys,
I've a white R32 GTS4 4dr, I had it for 5 years. Standard except for the exhaust (3") and the usual panel airfilter. Thinking about doing "stuff" to it :wave:
I'll post photo's soon
Yeah mate stick some pics up give us a look..
Here is my 1993 R33 4dr GTS25t
has a full 3" exhaust, front mounted intercooler, pod filter, Turbosmart Type II BOV and HKS Hiper D coilovers.
The wheels are 20 x 8.5" DUB 'Big Homie' wrapped in 225/30 nangkang tyres. They are NOT a $2500 Tempe special wheel either......
I have since purchased a Bosch 040 pump, Power FC w/ Hand Controller and some 740cc Nismo injectors. Am on the lookout for a decent turbo upgrade now and hopefully around 350rwhp.
Where are your tyres?
I like those rims, i would probably be scared to drive the car with those wheels.
By the way, any one that cant tell the difference between 20" cheapies and the real thing is not worth having a conversation with.
I would love a set of rims like that for mine, or for my celsior.
the tyres are there somewhere :)
they certainly dont make for a very comforting ride. I am going to get som 35 profile tyres next time to settle it a little.
1 rim has a small scratch, courtesy of my lovely girlfriend trying to curb hop!
Hi Lads and ladies, your pics, is that ride height or are your coils adjustable. Im looking at lowering my ride 93' r33 4 door (identical color match to yours) and was wondering if youve been defected for the height
Regards Evan
PS) Looks mad as!!!!
adjustable HKS coilovers, havent been defected in 12mths :)
touch wood....
Nice, where did you pick up the coil overs, and if you dont mind me asking how much.
Also, do you cruise around at the height in your pics or raise them up?
Im thinking of lowering my ride but dont want to get defected straight away and waste the $350 for a full new setup.
Regards Evan
Thanks Savage Bliss! Haha! - I'm still undecided...250-300kW and sleeper look, or 200kW + Vertex Kit = D1 look? Looking at yours makes me wanna go the latter... :(
Yeah I'm a fan of the sleeper! But also the latter :(
Any of you guys going to polish up the 4 door and come to Shepparton this sat 29
Well, i live in adelaide so it would be kinda hard BUT if you guys are interesed in comming over im trying to setup a foundraising cruise around adealide for the Leukaemia Foundation.
Regards Evan
Edited by EMZ R33
Hey Guys, just wondering what you people thought of my ride.
Mostly standard with the exception of new rims, Uni filter, stereo, window tint, custom parcel shelf (to fit the 4 way 6X9's in), and im looking to get it lowered.
Click on the links below the pic to see more pics of my Skyline.
So.....what to ya all think???
Regards Evan
Regards Evan
I got the coilovers 2nd hnd from 'spoolup' from the forums, paid just under $1K for them.
Car is permanently at that height, DUMPED :(
Guys, I need your feedback. Just changed the wheels on the R34 GTX. They used to have R32 GTR Wheels, now they've got the Kakimoto Racing 17" Wheels.
What do you guys think, keep the kakimoto's or put some 18" Wheels in different colour?
Link to pics are here: http://www.allblitz.com.au/cars/019_nskyline34gtxwhite.htm
Cheers,
Husnu.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
