  • Replies 403
  • 4 weeks later...
hear is my 4 door r34 25gt just picked it up last week and i love it. i was thinking of going turbo but i don't really trust myself at the moment so ill wait a couple more years plus i cant really afford one yet ill wait until i finish my course and get into the job i want. its pretty much stock except for the bigger turbo brakes which look awsome. ill have better photos soon.one more thing have u ever herd of the sticker on the back of my car it says now racing then in smaller writing nissan prince chiba racing team. has anyone herd of that before?
post-41250-1192758791_thumb.jpg Hey guys.
This is my R32 4door gtst. There is a few things i gotta do to get it they way i want.
Needs a manual gear box conversion
Bigger offset wheels so they dont look funny with the kit.
And the paint needs touching up in some areas. Also i have a cooler to go on soon.
By the way i am female :) lol
Hope you like...
By the way i am female ;) lol
Hope you like...
so someone finally bought that? that was on carsales for like 4 months.
hows it go?
hows it go?
Hey. Yeah the engine is really clean. Thats the main reason why i got it.
It runs well and is fast for a stock engine. Havent had any probs in the last 2 months that i have had it.
The paint is a little dodgy but i got a tin of paint with it to fix it up. The intrerior is immac. But yeah i was surprised it was on there for so long. I guess people were a little scared of a bit of work.
i think so... most people looking at that price range pretty much dont have much money spare to spend on fixing things up and i think from the comments from the 4dr section a number were a little afraid of the paint job ie. someone had just imported a rough example and got it in the backyard and sprayed it.
Yeah his dads workshop had a spray booth in it. So i guess you could call its a home job. The paint is good apart from the fact he hasn't sprayed the engine bay but alot of people dont bother with that. Also he hasnt taken out the window seals so it may peel back a little but ive got an air compresor and air brushing tools to fix if it does. But in the end i can get a respray for about 2,000. Its better than gettting a car with alot of engine work needed...
Nice ride Renee,
But damn, get some fat ass rims in there before someone sees you! It will look crazy with lowering, negative camber and DISH!
On a different note, I thought I would give my 4dr some love last week by jump starting it and listening to a couple of songs loud ......... anyway I have toasted another 15" sub thanks to a foul mouthed afro american chick who knows how to record very abusive songs both lyrically and literally when it comes to sub bass frequency. The moral to the story is don't let your pride and joy rot in your back yard and expect it to play nice when you dust it off! the list of things to fix gets longer and effing longer.
Ni.... you are a big poof.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
