OK, My R32 GTR is basically a toy, it has travelled less than 6000kms in the last 12 months.
It gets used for cruizes, and Track events and thats pretty much it.
The Current tyres that is was imported on now have exposed steel belts....so I figure its time for a change.
As I want to use it in more competetive events...and as I dont like to lose :O I want to replace the road tyres with a set of Comp R's.
I also cannot be bothered with 2 sets of rims.
I currently run 18" R34 GTR wheels with 245/40/18's.
As these tyres would see some day to day road use I dont want to waste big bucks on 'The Best' comp R tyre....
I have been quoted $330ea for a Continental comp R tyre imported from the states, which if I ordered now would not arrive until the end of July, but seems quite cheap.
What would you guys recomend as a good 'value for money' COMP R Tyre?
Cheers
Lindsay
Edited by PSI_GTSII
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/
Cheers
Lindsay
R comp tyres are inherently not good value for money. You can destroy a set in a day if you try hard enough. Having said that I usually find that in the larger sizes the RE55's are cheaper than other brands.
Be careful, as there are R compounds and R compounds. Not having heard of the Continental comp R I don't know if they are like the Re55's or closer to the up spec Falkens which aren't a proper R compound.
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2178799
These are the prices I got in 225/50-16 size for 'R' rated semi slicks. All around 60 treadware.
Dunlop D01J $365
DZ02G $379
Bridgestone RE540S $262
RE55S $262
Yokohama A032R $395
A048R $440
Kumho V70A $270
Toyo RA1 $290
R888 $293
The following arent 'R' rated and have a treadware of 180-200
Federal 595RS
Falken RT615
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2179969
The Falken RT's aren't advertised as an R compound either, aside from by pig-ignorant retailers. The Falken Comp-R's aren't street legal in Australia, so if you do find them they tend to be really cheap.
Comp-R's from the big manufacturers are within a couple of bucks of each other. When I looked at D01J's, D02G's, A032's and A048's there was a $20 (or 5%) spread for 17". The RE55s were $50 cheaper than the average, and the Toyos around $70 cheaper.
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2181068
So for a small amount of street driving and the odd competitive event (where I want to be competetive!)
Which would be the tyre for me then?
The cheapest R-Comp?
Go with the RE55's. Get the harder of the two compounds. Over here (ie WA) most people run either the Bridgies, or the Toyo's in the smaller sizes. So you wont go far wrong. Just look after them (ie get your suspension setup working), keep the pressures correct & understand that until you get some temperature into them they don't work well on the track, allthough are still better than roadies.
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2182514
i just put on a set of A048s which i'll use next monday. i have used the A032Rs on the group NC touring car before and apparantly on that car the 48s were nearly 1 second better. They are all absolutely bullshit expensive though which sucks. but if you want to go quick on road legal tyres these are the way to go.
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2182680
Rumour has it that the Michelin are the shit for road legal tyres. Unfortunately you need even larger wads of cash to go anywhere near Bibendum.
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2182754
mmm he is a chubby jolly little fellow but he sure loves to get in your wallet.
edit: i would believe that too. as we found on the GT3 cup car that at Eastern Creek the michelin slicks were a fair bit better than the dunlop slicks we had to run in one event (nations cup thingo).
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2182894
I think you will find the Yoko A048r are slower and more expensive than the re55s or dz02gs.
You either want the best or the cheapest semi slicks, no point hitting something inbetween
A Bridgestone dealer down here in Tassie ran a set of RE55's in Targa but swapped them for RE540's and said theyre a better all round trye. The RE55's are quicker on a dry track though.
Im getting a set of RE540's next.
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2183148
RE55's are one of the best and one of the cheapest! Just like you said!
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2183160
sorry dunc not sure if you're talking to me. my post wasnt clear. i wasnt saying a048s were the go, i was saying r compound semi slicks are the go for good times on street legal rubber. but from what i've seen the 48s are a step up on the 32s. have you had a chance yet for a run on some 48s? i dont doubt that the RE55s are better than either though.
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2183173
not personally but Gary should have some info. There was back to back testing done on them when the 3E cars were deciding new control tyres.
Despite poor results (overheating, too soft maybe?) even compared to the old a032r they were still selected.
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2183179
interesting. there are lots of compound choices (and size choices) in the A048s which may have swayed them. i still dont get it. if the bridgies are better, and cheaper (which by all accounts they are) then why is it time and time again yoko get a bigger slice of the control tyre market??!! must be good lobbying by yoko.
I'm running the medium hard compound so hopefully they wont be too bad.
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2183188
Last september I put 255 40 17 TT compound RE55s on my R33GTR and got 2 track days plus 660 ks of driving out of them cost $263.00 each, btw TT conpound is the second softest compound. Changed in February this year to RE55 SR medium compound 265 35 18 $326.0 00 and have got 6 track days and a couple of hundred ks so far with about 50% wear. If the ambient temprature is less that 25 degrees the TT were the choice less understeer. Over 25 the SR had a slower melt rate. I run 5.5 castor and 2.0 camber on the fronts. Fronts had 75 degrees inside temp to 85 degrees on the outside after 3 laps of mallala front and rear. I think they are good value for money compared to the dunlop and michelin offerings.
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2185281
The yoko dealer down here was trying to tell me the 48's are faster and can go through more heat cycles than the RE55's... but of course they are going to say that.. All the guys down here run the RE55s and say they are a faster tyre than the 48's , but the 48's do have a better wear factor....
RE55's are much cheaper than 48s as well...
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2186094
My Dunlops were old so its hard to say when i put on the RE55s whether they were better or not. I suspect that the Dunlops are better on my car...But the car felt better on the Dunlops if that makes sense?!?!?!
I am keen to get some DZ02Js, meant to be a bit quieter, and better in the wet...so most likely give them a go next...but if ic ant afford the extra $200 odd at the time i will just go back to the cheaper RE55s...good enough for what i do with a car .
Are you running cheaters tyres on your cheater car with the cheater engine these days...you cheater?
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2186125
yep. and those dunlops are the shizzy, give them a go.
Richard....the argument is they have the best range of sizes to fit production cars so they keep getting all the control tyre contracts. It is not because they are either cheap or good.
https://www.sau.com.au/forums/topic/118403-r-comp-tyres/#findComment-2187215
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
