I am wondering what the difference is between a Bar & Plate cooler, and a Tube & Fin cooler. I have been talking to a couple of workshops who reckon the Hybrid Tube & Fin coolers are better than the japanese brand name coolers, because the jap ones use a bar & plate design.
The workshop reckons that tube & fin is better because it is physically lighter and flows better. It also allows better flow to the radiator.
I was wondering if anyone else can confirm or deny this and also tell me which is better for cooling capacity.
The Hybrid Tube & fin cooler is $1400 supplied and fitted which I thought was a bit steep, but if it is as good as they make out, then I don't mind paying the extra cash. But is it really that much better than the $400 GKTech kit?
https://www.sau.com.au/forums/topic/118512-intercoolers-tube-fin-vs-bar-plate/
someone posted in the other thread that tube and fin is good for circuit cars etc, as they experience prolonged periods of power...but for street and drag, bar and plate is fine...
$1400 for a hybrid...ouch
Do a search if you want the full story, in summary……..
Bar and plate cores are good if you do short power bursts, they have more aluminium (weigh more) so they are a better heat soak. But they take longer to cool down. Hence good for drag cars and road cars that get short burst of power then cruise. They do limit the airflow to the radiator more than tube and fin cores.
Tube and fin cores are good for more constant power applications, they weigh less so not as good for instantaneous heat soak. But they shed heat quicker than a bar and plate. Hence good for circuit race cars and cars that see long periods of sustained power.
;) cheers :D
Hi quinny.
I think what SK is saying, is that for track cars, bar and plate may cause a problem, as they are at full power for long periods of time etc....on the street and at the drags, bar and plate would be fine...and im sure there are 1000's of members on here and other forums that have bar and plate coolers, and can tell you their cars arent dead ;)
I have a Hybrid super monster bar and plate intercooler and have no overheating problems it works well
if ur planing of running a bigger turbo setup and want more HP. go for the bar & plate u will be needing it to cool down the air alot faster than a tube & fin.
for a stokist setup tube & fin is the best way to go. better air flow and less turbo lag.
Rubbish, absolute rubbish, who the hell fed you that load of crap?
Some guy trying to sell you a bar plate intercooler I bet.
Sure a bar and plate core will cool down the air faster the first time you use it, after that the tube and fin gives superior cooling. Sure if you are into drags only, go the bar and plate, as long as you let it cool down between runs.
How many examples would you like of fast Skylines using tube and fin intercoolers. Let’s see;
1. the Gibson GTR’s all used tube and fin intercoolers and they won every meaningful Group A race in Australia for 3 years.
2. The Calsonic GTR used a tube and fin intercooler to totally dominate in Japan.
3. the Mines GTR uses a tube and fin intercooler, the bench mark by which all road/circuit GTR’s are measured
4. the Apexi drag GTR used a tube and in intercooler for 1100 bhp 8 sec ¼ at 160 or so mph
Shall I continue, there are several more pages of examples?
:unsure: cheers :rofl:
Thanks for the info guys, I think I might just stick with the GKTech kit, for $400 it is pretty hard to go wrong. I will probably get someone else to fit it though, coz I am useless at that kind of thing.
Hi quinny, I have sent you a PM regarding the cooler...so if you are in fact confirming as part of the group buy, can you get back to me on that PM?
thanks
bar and plate flow better than tube and fin. if you look in a bar and plate you will see that it just has a smooth end on it. tube and fin have the tubes protruding out a bit and some of the air has to do 2 180 degree turns (bar and plate do 2 90 degree turns) so there is slight turbulence. the best flowing of all it bar and fin (or tube and plate, can't remember which it is). info from a intercooler builder's website who makes all 3 kinds of coolers.
and bar and plate take longer to heat up, but also hold heat and take longer to cool down (as people have said) which is why bar and plate are used in drag cars, and tube and fin used in street/circuit cars.
Edited by mad082
Yet more unsubstantiated crapola.
Essentially, unless you are running a full race car, you will be fine with a GKtech which is the best value available at the moment.
I have no temp issues on the racetrack with a Hybrid Monster 800hp cooler.
and even better value for money in the group buy ! only $400 :O
lol
http://www.skylinesaustralia.com/forums/in...howtopic=117938
/end shameless plug
So having read it on the internet and regurgitated it, somewhat masticated no doubt (and a quick scan of the site showed nothing to support you 180 degree turn waffle nor is it a phenomena I would consider valid or of significance), you are now prepared to argue it with someone who actually does have somewhat more than a firm grasp of aerodynamic knowledge.
Once you can explain a few basics like settling chambers, von karman vortices, the navier stokes equations, turbulent wall growth or the meaning of a reynolds number I'll be prepared to listen, but I'll point out I'm not discussing with the owners of the website, or an expert in cooler design am I? In fact their website is a bit simple so I suggest searching elsewhere.
Look, learn but don't advise until you know, especially if SK is posting.
this is wat ive always been told in regards to coolers..
bar and plate coolers better but doesnt flow aswell as tube and fin
tube and fin flows better than bar and plate but doesnt cool aswell
yet in saying that was also taught this.. if you can only fit a small intercooler go for a bar and plate due to its cooling aspects
how ever if you can fit a rather large cooler in say something like a 600x300x76.. go for tube and fin for its flowing aspects..
feel free to tell me im wrong n wat not.. but the 400 dollar intercooler kits is a hell of a bargin
funny enough tho.. i run a 600x300x76 bar and plate cooler on front of the silvia.. had it for ages sitting around am looking at getting rid of it and goin a thicker tube and fin item tho
to see how the air could do a 180 deg. turn all you have to do is look into the intercooler. you can see the lip inside there. i'm not arguing that tube and fin are bad. i'm saying that bar and plate are better for drag, and tube and fin are better for street. and if you actually read what SK said and what i have said, i'm saying pretty much the same thing. if anything you sound like you are contradictiong SK more than me, so i think you should "Look, learn but don't advise until you know, especially if SK is posting."
The problem I have is the generalisation, not ALL bar & plate intercoolers flow better than ALL tube and fin intercoolers. To state the obvious, a 600 X 300 X 65 B&P core is not going to flow as well as a 600 X 300 X 150 T&F core. Then you have the poorly made B&P versus the perfectly made T&F.
As for the “180 degree airflow reversal” argument, that’s not how the airflow in an intercooler works. Think of the extensions into the end tanks as ram tubes or splitters, then you are much closer to the true airflow characteristics. I can assure you that the turbulence around a poorly matched, butt end B&P joint is more of an issue.
Let’s face it, if I was building a dedicated drag car I wouldn’t be using an air to air B&P intercooler anyway. Not when I can buy a dry ice to air intercooler with similar internal airflow capacity for a similar price. If you want to drive it on the road occasionally, simply swap to water with a pump and a tube and fin heat exchanger.
Horses for courses as they say..
>_< cheers :P
Edited by Sydneykid
But if you had any understanding of aerodynamics/fluid dynamics you would know that in those regions the air either stagnates or circulates while the primary flow follows streamlines directly into the mouth of the tube. It doesn't do 180 or 90 degree turns so that is a complete lie. Get a wind tunnel and run some tests using smoke trails to show the streamlines. I have, I think I'm suitably qualified to argue the semantics, and I suspect Gary would agree. All you are doing is confusing the issue and misleading readers with untruths, and then attempting to say "yes but I agree". If you agree, and have nothing further of value to add, read it and zip it!!! I'm not saying don't participate, just confirm what you want to write first, and not from a sellers site where they have a conflict of interest.
In fact that protruding tube, properly designed can improve airflow over an orifice with sharply squared edges of an equivalent area. This is basic stuff that a first year engineering student will learn.
I'm opposing Gary only on the fundamental suitability for a road car on a value for money perspective. I've never had engine cooling problems on my track car with a bar and plate 800hp cooler, but I was only doing a max of 7 laps at a time, in fact never noticed a temp spike in either outlet temp from the cooler or engine (well other than the back end when a cooler hose blew dumping flames out the exhaust >_<) but it was a quite a bit larger than the size SK tested. The prices available in dezz's current buy are the best I've seen and most users won't need to split the hair on "can it do 20 laps at full noise without temperature issues."
Which is best is a tough question to answer and the best answer is "It depends."
Have you actually read this that you wrote? I know you wrote it but but have you actually read it and tried to match up with some things called fact and reality.
bar and plate flow better than tube and fin. if you look in a bar and plate you will see that it just has a smooth end on it (Not necessarily). tube and fin have the tubes protruding out a bit and some of the air has to do 2 180 degree turns (bar and plate do 2 90 degree turns) so there is slight turbulence (total BS). the best flowing of all it bar and fin (or tube and plate, can't remember which it is) (I suspect wrong, any takers?). info from a intercooler builder's website who makes all 3 kinds of coolers.
I hope you get my drift here.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
