:P
Was it that bad? Were you smoking at the time though? I hear if you smoke in the weeks leading to the surgery it all goes pear shaped...
Don't worry Smooth, the pain is minimal and they give you enough heavy duty painkillers to last a month and you only need them for 2 days tops.
The REAL worry is if your wife/partner has a camera and takes a photo of you just as you wake up with a hot pink wraparound ice pack on your head and gauze hanging out of your mouth!!!
And if you smoke, you pay!!!! (As you should...... all smokers should die!!)
  • Replies 257
Posted Images
Dude seriously? If that information was posted up we would have a whole heap of unwanted attention, all im going to say is we didnt buy sports cars to drive them like girls (no offence to girls). A full tank of fuel is all you need, its a surprise events thing and if u dont have a licence i dont want you driving your car newhere near mine or most of the other peoples cars using this forum.
i was kidding john lol :D
Thats like me saying I never pop'd the clutch at 8000rpm in my car.. Or just made it blow flames for fun haha.
Smoothy sweet heart, advise around when this is going to be, I wana rep 20's and will have to hunt down some better tires for this road trip.
Edited by Nismo_Boy
You know, I was thinking these 'back to the old days' cruises have been tried before, planned to perfection, then flop. You need to give us 24hours maxium notice for it to be truly old school and work.
Just my thoughts...
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
