Hi All,
Yesterday when I went to pick up my replacement tail lights, I spoke to Wayne at GTAutos, with regards to the x-force exhaust system. It will cost me about $1,400 fitted and is a turbo back 3.5inch system. I tried to do a search to see if there was any reviews on this site regarding that particular model - but couldnt find any. Both wayne and his mechanic, run the system and say it does wonders. It sounds great too. My friend told me that $1,400 can get a good HKS exhaust. Is that true?
My question is, does it really matter what brand the exhaust is? Would something like HKS give out a better power rating? Would the car need a tune or anything if I do end up putting an aftermarket exhaust?
Any advice would be greatly appreciated guys/gals :nyaanyaa:
Thanks in advance
https://www.sau.com.au/forums/topic/118652-x-force-exhaust-system/
  • Replies 83
There will be a negligible power difference between X-Force and HKS.
However the exhaust note will be different. Personally I think the X-Force ones sound excessively loud and droney while the JDM branded ones sound better and also quieter.
And no your car won't need a tune after an exhaust system is fitted.
And from http://www.nengun.com -
HKS Hi-Power catback - AU $ 893.97
HKS polished front pipe - AU $ 308.80
and you'll need a dump pipe too
The xforce exhaust is based on the jap versions cept its made in china so its abit cheaper. They'll make pretty much the same power as all the others..
I've got the 3" xforce on mine and it made about 25kw or so.. slap your car on the dyno would ya cause i wana see what you get with the 3.5" please :nyaanyaa:
mines not to loud at all realy... infact when i took the silencer out i was surprised that it didnt evan get much louder.. it sounds pretty cool though i rekon, not as cool as a wrx though :nyaanyaa:
ive got a tanabe cat back, and let me say, tiz quite disapointing noise wise....some people would love the fact taht you get the gain of a 3" exhaust, but the lack of noise upsets me :O
justins xforce sounds tough, so ill be replacing my jap cat back with it shortly :)
1400 is a rip off
xForce Stainless Exhaust System - Skyline R33 GTS-T Price: $950
pay no more than 200$ for fitting
i picked up a mild steel one for 699$ for my old 33
they are louder and more droney than my current trust setup
but they do the job and their cheap .
Edited by arkon
So Xforce is the closest thing you'll get a skyline sounding like a Wrx? Can anyone who has one record some audio of it? I'm shopping for an exhaust atm as well.
skyline sounding like a wrx? maybe if it dropped a cylinder.
The roar of a skyline is far sexier then an wrx.
Wow, my X-force turbo back cost me $650 fitted myself.
From the cat back they are not any worse from a performance point of view but the big name brand cats and dump pipes are usually (but not always) better.
I would like to replace my dump pipe with a proper CES split dump and "high flow" my current x-force cat. The rest if fine.
Hi All,
Any advice would be greatly appreciated guys/gals :P
Thanks in advance
Edited by JCMarshall_Law
Hmm, I checked with x-force themselves, and another exhaust workshop. The RRP for the system is at $1600. The workshop qouted me a price of $1,500 (including fitting). I checked some of the online stores, but none of them have the turbo back system - they all have cat-back and then I will have to spend extra on the other items like the dump pipe etc. All in all, it comes to over $1200.
Anywhere else I can check around melbourne?
i see that ebay one has had the resonator cut out. wonder how much louder that would make it. i got the same setup but have the resonator in.
to get it sounding a bit different get an oval muffler, like a jasma or a lukey and take out the center resonator. a guy in town has that and it sounds pretty mean. different to most others.
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
