getting a 2 way might not be that bad. U might have scored a Pro LSD which u can adjust the preload on it....which is the same diff i have :D
How much preload variation can you get on this? Does it use the stock inner C/V joints / stub axles? Can you get alternative ramp angles for it? Was thinking of getting one of those! Cheers
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2191520
from memory 4kg, 7kg, and 12kg preload (ie soft medium and hard) Mine uses (in r32 gtst) stock everything. It should come with new stub axle bearings too in a new kit? Im not sure but mine was a complete overhaul done. Only thing is i want a ratio change now so im swapping to a 3.9 r200 shortnose crownwheel and pinion :D
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2191558
Thanks for the speedy reply! Are they available in both 1.5 and 2 way? Any idea if the ramp angles are available in alternative configurations for 1.5 way? Cheers.
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2191609
I'tll only step out if you want it to ie dont pop the clutch on a down change. If you are braking hard, push the clutch in and hold it (like u normally do)
Ive had to do an emergency brake before (some moron pulled across infront of me, then stopped) and i clutched it and braked at the same time. It stopped like a normal car would.
People seem to worry too much with these diffs....
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2193606
dude. take a pic of the damm thing about 3inches away from the whole!!!
i cant see shit in that photo. :starwars:
like phatr32's pic kthanx
whats this diff (its in the front of our GTR)
sorry for the lame pic...its the best i could do
https://www.sau.com.au/forums/topic/118708-nismo-lsd/#findComment-2198381
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
