Just looking at upgrading my turbo soon (rb20det), r32 gts-t Type Mcurrently have the following mods
3 inch turbo back exhaust
Unknown cat converter
pod filter/sectioned off
running 12 psi
FMIC
Performance suspension
Looking to make the thing a bit faster. Dont car about how many KW ill be pulling (expect 190-200)
Looking at the 25 series 2 turbo with the nylon wheel. Dunno if ill be able to afford a highflowed one unless i get 2nd hand or something, heard quite a few different prices but was hoping for somewhere around 800 or 900 installed.
Anyway just looking through the dyno thread sticky and most people just post KW's not 1/4 mile times, although one guy posted a time of 14.65.. which is like .15 better than a stock 32 gts-t. Weirded me out. Any one give me a rough idea of what i should expect to pull on the 1/4 (e.g. how much better than the stock 14.8) on some good quality performance tyres with performance suspension with my mods and the 33 turbo? Perhaps the time rough amount faster the highflowed is gonna be, would help to if u know that.
If its not significantly better then ill just leave it without the bigger turbo, and try to make do with what i have :D
Did try do a search but the criteria is to open and at the same time to specific to get some decent results. if anyone finds otherwise, feel free to post that link here for me :D
Some 0-100's would be handy to (stock gts-t's hitting that in about 6.9 i think)
Edited by r32 gts-turbo
https://www.sau.com.au/forums/topic/118921-wat-sorta-quarter/
You can get 160-170 on most RB20's running about 12-14psi depending on a few things...With a RB25 turbo your probably looking at about 180 mayb a few more at the rears...
As mad082 said, it comes down to driving, and how the car is setup. If you have crap tyres and crap suspension you cant expect to get a very good time because u will have trouble trying to put any of this power to the ground anyway regardless of what power your making. i would say high 13's is quite realistic with supporting mods. But that sed...all depends on the conditions on the day aswell.
Yeh tru all that, i think its reasonably well set up with full springs shocks under konig brand name (very damn hard suspension) and some 17X7 dunlop SPMAXX's which are top of the line (not to mention i weigh 55 kilos :)). Totally messed up somewhere in my readings somewhere though. Forgot to mention that i will Probably be running 14 psi on the new turbo with a remapped ecu but yeh. High 13's would be just wat i want, especially if i can get it with the series 2 turbo without having to have a highflowed one. The car could be quite detrimental to the ego's of stock $60000 performance cars everywhere with acceleration like that, sounds just about right :rolleyes:
running the extra 2 psi = no power gain and shorter turbine life? I have read of quite a few people running 14 psi so i assumed it would be relatively safe.. Cant see how it wouldnt equal a power gain though.. Up to a point more psi = more power.. you could probably get more power all the way until 20 or something id say (read something somewhere about flow and such which seemed to imply that too much compression would equal slow flow or impeded flow rates, something like that)
correct me if im wrong
you wont be running 14psi for long, maybe 6 months to a year. Wont you be just adding a hole lot of heat for no power gain
Its on an RB20... just incase you've missed that posted a dozen times.
RB20 you can run a little more than the R33
whoa whicked if i can hit something like that ill be very happy, time to start looking around for a turbo to lob on. Guess the for sale section is a good place hehe.
My old R32 with remapped ECU (thanks to Matt Spry) and standard turbo pushing 12psi managed a 14.3 on my first run with G-Tech. Tuned for 15psi I managed a number of runs between 13.7 and 13.9 (again with G-Tech).
Yeh tru all that, i think its reasonably well set up with full springs shocks under konig brand name (very damn hard suspension) and some 17X7 dunlop SPMAXX's which are top of the line \
Hard suspension will make your time worse, and 17x7 are the size of your rims, not tyres.
I am taking this from another thread which may have a generous dyno, but still none the less it prooves 160-170rwkw is easy (ive seen that on stock rb20 turbs) and 180+rwkw is a good goal for an rb20 with 33 turbo, obviously the 34 turbo will make a tiny bit more than a 33 turbo as im sure you aware.
You should be able to do a mid 13 with an rb25 turbs if you are a good driver :)
running 12 psi
FMIC
If its not significantly better then ill just leave it without the bigger turbo, and try to make do with what i have :P
Did try do a search but the criteria is to open and at the same time to specific to get some decent results. if anyone finds otherwise, feel free to post that link here for me :ermm:
You can run a little more boost on the RB20 with the RB25 turbo as the engine is smaller in size with supporting mods and 14psi 200rwkw is probably possible but im not sure how long the turbo would last at that boost level.
I managed a 13.6@105 with a crap 2.4 second 60 footer on a 30 degree day, with my R33 first time at drags. So in your case with similar power less weight better tyres and suspention high 12's may not be out of the question.
Ohh really? I suppose it IS set up for handling, uhm so tighter suspension = more bouncing, is that it? Wouldnt tighter suspension stop the sag more and help distribute weight around more evenly on take off. Not sure on suspension stuff
And yeh i know 17X7 is the size of my rims, the car was nowhere near me. There 225/45R17 Dunlop SPMAXX's which is basically dunlops top performance tyre so i think there cool for a bit.
Curious though, you 2 guys who ran mid 13's were your 33 turbo's high flowed? series 2 or 1?
Thanks (had to spend $1000 getting a new computer to get onto SAU, just when the turbo was within my grasp demit)
And yeh i know 17X7 is the size of my rims, ill post tyre size a lil later on, the car was nowhere near me. Its still not near me but they are very well fitted (did em myself :P) and definitely not to small for the rim, the sidewalls buldge slightly as a rim protector (with to thin a tyre they won't sit out) so there definitely wide enough to be putting the power down alright (can drop the clutch at about 4k RPM and get pretty good pickup).
do a search for posts by sydney in regards to drag suspention.
cheers
Well i made 162rwkw @ 14psi on a stock RB20 turbo.
Full exhaust, re-map, fuel pump and thats about it.
Dunno how but hey i was happy for so little mods.
But there are always those freak motors around etc so i'd be expecting maybe 170ish from a R33 turbo but you never know i suppose so whack it on the dyno and find out!
Edited by MADGT4
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
