Hey Guys... im going to attempt to install my FMIC in the upcomming weeks and just QRI05E (curious) :) to know where is the safest part to place my jack stands while working on the car?
Could some one please post up a pic showing where to place them under the car??
Cheers
https://www.sau.com.au/forums/topic/118956-jack-stand-points-needed/
um i placed mine just underneath my suspension arms (actual name fails me.. wishbones or something? i duno, independant bits at the front) on the rubber washers just as they join up with the rest of the under carriage. probably the best place to jack as the front as the sills will be a bit to far back for stability and are rather hard to access if youve got a kit.
Edited by r32 gts-turbo
i cant put them under the frame rails due to my trolly jack being too high to fit under the car after lowering it 3" : can anyone please post up a pic??
cheers
i know what u mean...
i have 2 ways of jacking up my car..
1/ piece of wood and bricks, which i drive the front wheels on and put the jack under
2/ get a scissor jack, jack it up from the side enough to get a mini trolley jack in, then get the big trolley jack in the front..
either way its a bitch
Try the frame rails under the floor but put a rag between the rail and stand.This will protect the paint.
Are you talking about the chassis rails? I was under the impressions it is an extremely bad idea to use these are jack points as they tend to bend and buckle.
I recall reading something somehere (either SDU or one of the UK forums) about a similar topic.. there's a nissan made part specifically for jack stands and skylines. I did add the item to my post skyline purchase shopping list (nissan part# LM450-60000), but don't know how much, or if they're available here.
  • Like 1
i use the points that ive circled below.. not sure what its called.. can someone tell me if its alrght to use them ??? im also curious where the correct place to put the jack is... i always get realy paranoid the car is gonna fall ;)
between the two circles is the front cross member/subframe, that is a good place to use. Be careful since the sump is a bad place to use. there is also the tow hooks at the front they are great jacking points.
also be very careful if you are putting the jack under the side of the front subframe, the lower control arm is not safe - it moves relative to the chasis when you jack the car up.
chasis rails are OK to put stands under *if* you use the thicker area towards the front and let the car down slowly. even better if you have to do this use a piece of wood on top of the chasis stand along the rail to spread the weight.
at the rear, like the pic says, use the diff or rear subframe.
the sils are a no no they wil crush for sure unless you are using the nissan scissor jack or a hoist with rubber pads (and sometimes even then)
tow hooks are great, strong weld to the chasis and easy to get to....I was pretty nervous at first, have a good look at how they are fixed to the car....I use them all the time now, so easy to get to :)
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
