  • Replies 41
well. i get the feeling that its generally disliked...
... im gunna make a bold move and say i like it... photo shopped or not, it's pretty original (from what ive seen anyway) and i like how clean it is. however a good point is made with the transformer lookalike thingo...
cheers. James.
I am not so sure it is photoshopped. Custom hinges are not uncommon nowadays, neither are airbags. The back wheel is on a funny angle in the pics where it is dumped, but it looks consistant in all the pics. The shadows look ok to me, so I am not sure where that conculsion came from. I have looked at these pics trying to find inconsistancies, and I can't find any, which would be rather hard if all the pics were chopped.
If it is chopped, then it is a very good job, someone has put alot of work into it. If it is real, the owner needs a slap upside the head for doing that to a perfectly good Accord. Personally, I think it is real, someone has gone to alot of effort to make this a show car, but its appeal is limited. This is a good example of money not very well-spent.
yeh, i rkn this one is real. you can see the split in the bonnet in the 4th or 5th pic(s), add a couple of struts, that explains the bonnet. you can see the airbag setup in the boot (u can just see the 2 black tanks). the boot opening up like that has been done a million times, just hinges/struts. the door setup is just hinges, nothing special about that. other than that, i cant really see anything to make it seem as tho its been chopped. as has previously been said, there are some pretty crazy cars over there. anyone seen the 300ZX with 2JZ and massive single turbo setup?
Edited by VB-
think i'd rather have the VX commo in the background with the monaro style lights. the interior on the accord seems really tacky with the switches n pressure guage, considering they've gone so far with the outside of the car. looks like they've just used a self tapper through the woodgrain panels
dohhhhhhh :D
It's actually a deceptacon.
Moments after those photos were taken it turned into a pile of crap...or was that before?
I've spent a couple of weeks in the UAE here and there and the guys in that part of the world certainly have their own "style" :D . But in the end who cares, its mums 17 sec shopping trolley.
and now some dancing fruit!
:PBJ: :PBJ: :PBJ: :PBJ:
Looks like the 'merican "niggoz" have to catch up somewhat. I dont mind looking at the stuff, but i'd never own it. unless I had Sheeetloads of money, even then it would be say, my 20th car. much nicer cars to spend that kind of money on! with, say, performance!
Gotta ask tho, what is the point? does it all boil down to impressing chicks? or impressing yo' boyz? which begs the next question....
Edited by jezzerrr
Joissezzzzzzz :|
Doesn't their religion teach to be conservative, & not so dam flashy & boastful with their money... & if it doesn't... well it f#cking should!
Yes Islam does teach to be humble, and not to be a spend thrift.
Unfortunately the Gulf boys have a problem with showing off.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
