how fat are these fat rims dave?
They really arent that fat, just spaced out (front have 1mm caliper to wheel gap) rears are 235s, but the dunlops seem fatter than the equal bridgestone tyre. Either way they grip REAL good, considering they arent fully run in yet either.
super man, the man
Hey f**k head, if you have a problem with the clutch then maybe you should ring the people who rebuilt it. Let me guess, you dropped it from 7 grand 20 times and the clutch didn't like it. Geez that's too bad.
hmm im not feeling alot of love in here
There is no love. Don't worry, you think Greg is your friend now but he will stab you in the back later on. He will say and do things and then deny ever doing or saying it later on. I know of a few other friends he used to have but he shat on them also....all for stupid reasons. But clearly Greg thinks it's a game.
And putting signs up on people's cars and doing burnouts at service stations and other equally stupid places is only proof that he is a knob. If he ever cares to grow up then he will see what he has created. And instead of being mature and trying resolve the issue he just hides behind his Dad. I was warned against doing anything for him from the very beginning by people who he called friends and now I know why. I regret ever meeting the little worm.
F**K Shane...
Im filled with anger... I really am...
A mate of mine was beaten and thrown on the railway lines. I really hate those sorts of people. I guess it pays to go out in large groups. Dont you just wish you had the chance of returning the favor to those who did it to you. Lucky your in one piece tho man, a guy was stabbed to death last saturday night for his wallet in breakfast creek.
A mate of mine (who is a tiler) had to work on a few railway stations at night for obvious reasons. Replacing that little yellow line on the edge of the platform with a row of yellow tiles. They had 4 rail security guards to stay with them at all times while working due to the drunks and the gangs who seem to love QLD rail.
I don't seem to get hassled either...... don't know why...... must just have that don't-f@%k-with-me aura?????
Although, it seems that little guys with a large chips on their shoulders do try every now and then.
don't know why you don't get hassled Dave... you look like a pretty easy target to me? :D
and yeah, it seems to be the young kids with something to prove who make the biggest stand...
at Bray Park train station i had a group of about 5 or 6 young teenagers (up to around 16) come up to me as i was walking across the overhead bridge (alone)
the youngest one stood in my way and wouldn't let me past, started mouthing off, pushing me etc...
i ended up picking him up with one hand and 'gently placing' him into the railing.... his friends sorta backed off a bit but another one decided he was going to be a tough guy and put out his cigarette on my arm....
i just looked at him like "wtf?", gave him a gentle tap to the stomach and continued on my merry way to catch the train....
another time i had some guy following me down a dark street in the city, he was walking faster than i was to catch up... i knew he was there for a couple of minutes... when he eventually caught up, i just turned around, ready to smack him one, and he freaked out... wasn't expecting me to notice him, and ran off like a little girl... haha... i saw him in a club again later on that night and he basically ran away again
They have probably all noticed you from somewhere before, but they just cant place where... Then 3 months down the track they work it out when they are back in the lock up.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
