yeah welcome to the future
the story I heard was the car had a for sale sign with a phone number on it, and they got busted .
I thought they were two different things? Ie this one went as planned, and the one with the phone number on it was some tool who thought it'd be funny to take off his number plates and do donuts in front of a speed camera van, forgetting his phone number was stuck to the window.
Could be completely wrong though, the number of urban myths and general misinformation getting around on the net makes it hard to know what's right and what's not.
he he he
I'm now officially a member of SAU QLD and have access to the members’ area.
he he he you can run but you can't hide. :O
:laugh: Just bored really and looking for some one to talk to.
Good aftermorning.
(too tired to care, the small one decided that he would continue the chillan vibe waaaaaay into the wee hours of this morning, and succeded in his plot to make us let him sleep in our bed.)
This one is way to smart for his own good. :O
well for now i have no licence so i wont be that annoying but wait till i get it back in DECEMBER!!! ha ha ha
i'll be at every event annying everyone!!!
he he he :( i get my licence back a few days before my birthday
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
