is it that bad????
what i showered last tuesday!!!!
i'm gonna prolly have to shower again tonight for dinner................................maybe...........
:dry: predicted to hit level 4 in October people!!! do your part!!!! :(
STOP ALL FORMS OF SHOWERING!!!
FORGET WEARING CLOTHES COS THE WASHING MACHINE IS USING UP ALL YOUR WATER!!!!
FLUSH THE TOILET ONCE ONLY AT THE END OF THE DAY!!! (consider using a shovel to dig a hole in your back yard)
Not only will this save water for you you will save big $$$$$ as water is more expensive than petrol and most soft drinks (which actually have water in them)
end rant...
is it that bad????
:) predicted to hit level 4 in October people!!! do your part!!!! :laugh:
end rant...
That IS WRONG LEE!!!!!! :O
You = :yes:
On the news they are saying ppl are better off without tonsils, my brother got his out but Ive never had any probs with mine just the sinus's.
lol well thats the funny part I got the same symptoms as tonsillitis but I don't got tonsils ????? :O
How did you go with the manifold daz?
At least they have gone back to the round tailights for the new model, somebody has some sense of the skyline heritage.
i havent had a chance to get my mate to have a look at it yet,
i just got a new manifold gasket today for it so il be going to see him to book it in 2moro sometime then hopefully he can find out what the problem is......
he he he
i know you like those bags dave and i reakon anna loved her's....
wasn't what i expected, everyone talking over everyone else, heaps of fun, Linh said OMG dave is old but he is one rude man..... he he he
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
