you see, you must understand young ian, that the world revolves around "pants". without the "pants" you are nothing, and cannot participate in the "great circle of pants" just like in the lion king (but with out elton john) if it has no pants, then it does not exist. there is no meaning to life without "pants".
for when your pants die, and you throw them away. a homeless man finds them, and continues to use them until he gets collected with the trash that he sleeps in. thus dying under the overwhelming smell of garbage and soiled nappies. the pants go with him into the ground, and eventually a "bum tree" is born in its place. from this tree sprout more bums, each with a little bit of those pants, used as a loin cloth.
and so it is that the pants continue this cycle until there is no more to make loin cloths. then the bums discard the loin cloths and mug someone, steeling his pants and the cycle continues.
do you understand now young ian?
sounds as clear as mud Michael :)
glad to see i've enlightened some people with words of wisdom.
although somehow i feel we have all become stupider just from reading it
He saez he was driving quite normally and cut the corner a bit, hit the gravel and ended up against the tree, no real damage except for a dented guard and it bust into flames, he is insured tho.
OH boy Charmed is back on woohoo!
i like that "HE SAYS" lol ouch to him i guess, trying to get his money out of the insurance company.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
