hey matt whats new??? been a while
hey hey, yea has been...not too much is new. Went down the spit today, saw a few sau cars, noone i recognised though. Btw i have a lexus now, as per you probably guessed in my av. I am deprived of big turbo power :-( Whats new with you?
lol well apart from the little guy ( cant believe he is 9 mths old Next Friday :O ) ah not much same old same old still working for the council hahahaha
Still working on the Honda just about done :D
not my car one of the guys projects 209bhp :laugh:post-146-1169384684.jpgpost-146-1169384702.jpg
hrm, lets see how long the police take to get here for a 000 call...
been 12 minutes so far...
i think someone was just trying to break into my house... was in the dunny and in the room next door (bathroom) it sounded like someone was trying to pull the grill/flyscreen off the window... had about 4 or 5 goes at it, then i heard what sounded like at least 2 people walking around on the grass (have an open window in the dunny)
ok, cops have been, got here about 1 minute after i posted that last post actually, so good response time.
we had a look around outside, can't see any sign of anyone trying to get in etc (no crowbar marks on the grill etc)
i've turned all the lights on and am now walking around with a tyre-iron :laugh:
man last time I dialed 000 for myself I was being chased by car theifs and the cops didnt want to know about it.
Personally I think there fu*king useless, but everyone has different opinions.
buy a police scanner, listen to then, they are useless,i listen to two cops call in chubb security to watch a place that had been robbed as the cops were too busy, the cops then called in and asked for outstanding jobs, there wasnt, so they went to dinner :laugh:
and listening to them get lost, and asking for referdex directions uselss
i had an experience like that, 2 black guys were scoping out my place, i was just sitting down having breakfast when i saw them walk down the side, then they were peaking round the back corner of the house, i could see them from the kitchen (our windows are tinited, they couldnt see in) they then came upto the kitchen window where i was, so i grabebd the phone, called the cops and watched them as they went round the other side of the house and heard them trying to get the screen off the sliding window, at that time the garage door opened as my mum was ocming home and they bolted! what made thigns really bad, was i was home from school with a torn ligament in my ankle and i could hardly walk! was freakin sh!t scared let me tell you :laugh:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
