SLAYER!!!!!!!!!
\m/
ROFL SLAYER
ahh the fun!! What about chaos or even further back boxhead...what ever happend to them, apart from being banned. Man it used to be fun having stupid convos in whoretown with charly going off his nut. Even funnier was that night at cactus jacks...or the dyno day where josh ran unlimited boost...not to mention the noosa cruise!!! omg good times.
meh
charly's disappearing act is working a treat for everyone
heard of slayer's old days and wouldnt mind hearin more of them actually
only old skewler around now days is marc
Lol the slayer thing just went straight over your head
Dunno, haven't seen much of him at all. I miss his gratuitous plugs for Chapman & Chapman :yes:
Eug is still pretty active
hahaha yea, havent seen Eug on here in a while either...maybe i just miss it when he posts. ALthough im not on here all that often anymore...glenn was funny, but his dog was funnier, what was its name arghh i've forgotten!!
ROFL SLAYER
Hehe yeah
Or when Boxhead was still Boxcar_Racer or however it was spelled, before the death of his 32. Twice IIRC
*sheds a tear*
Ooh time for lunch... bbl
Hehe yeah
*sheds a tear*
yea it was twice.
long after boxhead was that 180sxdogg (swear they had to be related) and he signed up under about 30 other users but all were banned. Hes been banned from every car forum there is i'm pretty sure.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
