I drove old yella just then...
She went super sonic 28psi down bridgeman road in 4th gear spinning the wheels...
Was a hand full but i got her home with out setting her on fire... :pwned:
It turns out i didnt put the external wastegate correctlly...
This is my first experience with an external and after doing some searching on the web i found a really good description on a jamican car forum...
Thanks Jamica... You have saved me from blowing up my engine...
Ill wait for the car to cool down and then ill go and fix my simple error...
Here are some actual maintenance complaints submitted by US Air Force pilots and the replies from the maintenance crews.
Problem: "Left inside main tire almost needs replacement."
Solution: "Almost replaced left inside main tire."
Problem: "Test flight OK, except autoland very rough."
Solution: "Autoland not installed on this aircraft."
Problem #1: "#2 Propeller seeping prop fluid."
Solution #1: "#2 Propeller seepage normal."
Problem #2: "#1, #3, and #4 propellers lack normal seepage."
Problem: "The autopilot doesn't."
Signed off: "IT DOES NOW."
Problem: "Something loose in cockpit."
Solution: "Something tightened in cockpit."
Problem: "Evidence of hydraulic leak on right main landing gear."
Solution: "Evidence removed."
Problem: "DME volume unbelievably loud."
Solution: "Volume set to more believable level."
Problem: "Dead bugs on windshield."
Solution: "Live bugs on order."
Problem: "Autopilot in altitude hold mode produces a 200 fpm descent."
Solution: "Cannot reproduce problem on ground."
Problem: "IFF inoperative."
Solution: "IFF inoperative in OFF mode."
Problem: "Friction locks cause throttle levers to stick."
Solution: "That's what they're there for."
Problem: "Number three engine missing."
Solution: "Engine found on right wing after brief search."
there is a redhead , a brunette & a blonde having coffee talking about their teenage daughters. the redhead says " i was looking thru my daughters drawers the other day & found a packet of smokes ... i cant beleive my little girl smokes " the brunette says " well i was looking thru my daughters drawers the other day & found a bottle of whiskey ... i cant beleive my little girl drinks" the blonde says " i was looking thru my daughters drawers the other day & found a packet of condoms ... i cant beleive my daughter has a dick
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
