Your old
I'm not.
Your career life can only go so far
Mine can't isn't capped
HAHAH, wana play more gordo pooky
From what i see yours will only be capped by the time you spend on here instead of pursuing said career. :worship:
Me being the real estate and development tycoon that I am does need a license, to contuine on working. I'm calling this time, another hoilday :D
Me being the real estate and development tycoon that I am does need a license, to contuine on working. I'm calling this time, another hoilday :worship:
And are we any wiser as to how long this "holiday" will last. :D
