don't you people have anything better to do with your days than spam useless crap on websites (including this one) all day, every day?
geez..
if you ask me, this thread should be closed PERMANENTLY
It's a casual way the more social forum members can talk to each other through out the day. Perhaps as a general chat thread some guidelines need to be set out, but I don't see why it would have to be closed permanently.
geez..
I agree with the first part, def disagree with the second, here is where we get to ask the hard questions, if it fails for a response then you know to start a thread about it, if you can sometimes wade through the spam, that is.
And just to change the subject, Im glad I dont live in Russia.
More than one hundred coal miners are confirmed dead in the Ulyanovskaya Mine disaster, Russia's worst mining accident in a decade.
look i have nothing personal against those members that frequent this thread..
my issue is the reputation that comes to SAU as a result of actions of those who have a tendancy to whore threads, eg the events of those who got so bored that they went over to other forums and tarnish SAU's image
when i see posts like "in for page 1", i just don't know why people bother even posting, wasting bandwidth, and actually making everyone who reads it lose functioning neurons
the way i see it, the best solutions are:
1 - close this thread, and just head on over to the wasteland section of SAU
2 - post all your MSN usernames in your signature and just chat on MSN.. this is a dedicated program for chatting
forums = for posting threads and sharing knowledge
chatrooms/instant messaging = for random chit-chat
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
