yeah, i blew a cooler hose in brisbane one day....when I first heard the sound I was pretty worried....lucky for me I had a mate that lived down the road as I didn't have a socket set with me at the time :laugh:
WHEEEEEEEE! YEEEHAH!! VROOOOOOOM VROOOOOM!! OH yeah BABY!!. GIVE IT TO ME. POWAH AGAIN AT LAST. VROOOOOOOOM
KABOOOOFF WTF...... FARKIN COOLER HOSE AGAIN.GRRRRRRRRRR.
walk walk walk walk walk(5kays) Gets socket set that should have been in the car. walk walk walk walk (5kays) fixes pipe. Opens glove box to put sockets in. AAAARRRRGGGGHHHHHH!!! 2 farkin shifting spanners laughing at me.
sigh
lol.. so noel any noticeable changes..?
and u get them from slide for 560 or whatever it is..?
yes its much better mark. I can boost it back to .8 bar where it was tuned. before the new coils it wouldnt run past around .5/.6 bar.
And yes, after much dicking around I did get them from Arron at slide. (the dicking around was caused by both sides so no argument there)
Hint for people who blow hoses alot (eg me) make the hose at the top of the engine bay looser than all the others...that way if it is going to blow it blows that one off and it is the easiest to fix :laugh:
lmao. Wouldn't it just be better to stop any of them from blowing off. 22 pound and the only ones that ever blew on mine were ones I forgot to tighten up.
Tip for new players would be to go to LHS and buy a bunch of decent hose clamps. They are still a worm drive one but have an incredibly durable housing which can be cranked down really tight.
They go for about 3-4 dollars a pop.
I blew a balast in one of my head lights (HID) and cant find a replacement :sleep:
The ebay user I bought the kit from no longer is registered... So i cant even buy a new one from her...
Looks like i might have to fork out for a whole new kit :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
