i do my research little man, and for 6k u could get a set of protek suspension, plus u'd have 2k spare from a set of 50mm dms suspension, ohlins arent that expensive u douchebag :P fark i'd want a set of sachs for that kinda coin ;)
u feelin me?
feeling ya lol..
it was 6ksupposively got reciepts.. fitted somewhere in sydney and corner balanced all the proper shit. and the ohlins are from germany. and are alot better than the teins, nismo S-tunes and bilsteins.. ill show u them so u can cream ur panties yo.. ;)
feeling ya lol..
it was 6ksupposively got reciepts.. fitted somewhere in sydney and corner balanced all the proper shit. and the ohlins are from germany. and are alot better than the teins, nismo S-tunes and bilsteins.. ill show u them so u can cream ur panties yo.. :rofl:
sachs are european too, sachs are the coilovers that are on the z-tune :worship:
i've seen ohlins and yes they are porn, but theyre pretty useless/wasted on a street driven auto r34 :rofl:
IM BACK!!!!
dammit, i wasnt sure if i locked the door or not :)
meh.. not street driven anymore..
as if we never got around to the manual conversion...
hmm...
HEY COL..
where did you go..?
HEY COL..
where did you go..?
Japan... Also moved house, so had a 3 weeks wait on ADSL connection...
Now I have a week away in Sydney for second half conference. So ill have limited access again for a week.
But the good bit is from Sydne I get to go to Cairns for 3 days before coming back to Brisbane. So im stoked, as Ive never seen Cairns...
cookin dinner, where are you?
Just got home from work all day, then i have to go out and work again tonight at 10pm. Then in the morning at 8am. Im Farked already. :)
What you doin dingo workin out ur motor.
Just got home from work all day, then i have to go out and work again tonight at 10pm. Then in the morning at 8am. Im Farked already. ;)
yeah chiselin away at it sub. Its coming together nicely now mate. :)
Does anyone have any feedback on XFORCE exhaust headers are they shit and warp with the heat. They look like pretty good quality.
low mount or top mount?
My mates ca18 low mount held up well, mounted well and never cracked. My other mates low mount on his Sr20 is an awful fit, needed longer studs and just doesn't look as clean as the one made for the ca18.
Another mate bought a top mount one for his ca18 and had nothing but trouble with the waste gate flange cracking off.
I have read some people have needed to mill the flange down, as it was uneven too.
pics or ban?
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
