boo
Heheheheheheeh
Boo, is that all you have got to say?? You can do much better.
And Markimak, they are all on another forum. Shanef is still the same, flames everyone with little or no regard for anyones feelings, but it is funny.
ever want to sell a car use carsales. i had all up over 15000 people click on my ad to view it. and around 500 calls over the months i was selling it. soo many people wanted to drive only 3 did.. and the 3rd brought her well traded :pirate: . :blink:
how did u go about it.. im interested..??
put ~10 rolls of duct tape over the cut area, secure the line so it wont move, using an angle grinder with a very fine cutting blade, cut through the hose as quickly as possible.
hahah I gave that away a long time ago. Not everyone can wait like you Marky.
FARKEN ZING :sorcerer:
on the other hand i will post and continually voice my opinion that ur all gay IT nerds and GTSTs are slow :(
im not an IT nerd, and yes, GTST's are slow :)
think this will hold up in my mates RB25 sil..???
patrol pressure plate with different dia frame and a exedy heavy duty cluth plate
yes, but he'll blow the rb20 box :yes:
emos can go die..
+1
i like my SR 4 potter...
lol @ rocker arms
Re: people who budget build.
Why use cheap shit. Do it right and use something decent.
why? so u can get the car back up and running. and to add another to the count :P
and build one on the side ;)
joshies missus
when did he start dating ur mom?
Heheheheheheeh
hi dave :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
