Hey guys is this normal, i received my exhaust manifold today but i dont think it will fit. when you line it up against the block the mounting for the housing is on an angle towards the block. My current set up has the housing sitting level. Can you adjust the housing to fit like that on an angle, I am not sure.
yes its normal sub. Dont sweat it. the housings can be rotated to suit.
Arh thanks Noel thats good to know my mind is at rest now. When i lined it up i thought f**ken shit shit shit shit shit :):(:domokun::domokun::domokun::domokun::domokun::domokun::domokun::domokun: .
Get that thing off ya bed, now that would look great in my car :laugh: .
no
yep...top quality work there shane....lol.
go fark urself
Nice bed sheets shane... :)
thats a doona cover u farktard :)
side note: pulled the head off, and pistons & rods out of the motor today. gonna get dan to check the clearances and put a metal headgasket on and maybe headstuds if i can be bothered/wanna spend the money
WTf are you doing bitch. Rebuilding engines that havnt even been run yet. :)
Seriously Shane, You arent reall going to complete this car are you. :laugh:
Not rebuilding...just being thorough. Over the Hill pulled a piston out so who knows. Best to be safe than sorry
WTf are you doing bitch. Rebuilding engines that havnt even been run yet. :blink:
Seriously Shane, You arent reall going to complete this car are you. :yes:
sif i'm rebuilding, just doing some checking :D
it's ok, i found no trace of sand :D
I definitely now know my clutch was stock. It lasted two 2 days :(
so spilmer, what she make mate?
mate of mine has a gtir that runs like a dog at the best of times, we went for a spirited drive on Saturday night and the motor stalled on de-acceleration and now refuses to start.
Anybody point me in the right direction of someone who has experience with these things cause everywhere it has been since he has had it have dicked him around.
basically looking for an honest mechanic who can work on a gtir
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
