i havea myspace stalker.. how gay
ahahahahahaha unlucky
I just got another call about my car. "so your car is for sale?" "seems like it" "would you sell me just the mirrors and the JDM tail lights?" "What do I do with the rest of the car then???" "um...dunno....wreckers???"
DO i wait till early december for the better deal on my car or do i take the slightly less good deal tomorrow *strokes beard*
If it was me id hold out till early December but im kinda bias...wish i could do something now to secure a deal Andy, or if we had of met before you could know how legit i am.
I'll just keep my fingers crossed. If im not to late allready:S
Edited by Tyc
fulley schick pistons maaaaate....!
/end guzzi voice
looks like there is movement at the station
slowly lol
only reason i got these now caus they came up cheap, too cheap to let them go :)
what rods you using? I see they have the oil squirter relief in the bearing face....nice!
Did you want to organise to bring the car around on the weekend preferably saturday? And we can set a plan in motion and start doing stuff...cause i go to america for three weeks from december 20th. 5 weeks, i can see you and me talking shit moreso then actually doing work haha.
We'll do it on saturday Mike. cya then. :wave:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
