i think mark was talking about the 'copy' drifteks. not the ones you have
nah no copy drifteks
but the old 4 stud ones and 5 stud clear easially. but the new 9 hole ones im unsure of. they just clear R33 GTST calipers
no i dont think there are copies of driftteks.
bee*r rims are different and look hotter but for the price i would buy the 18" teks when they arrive...soon very soon.
yeah i might wait for 18"
It cuts an ok ring :)
new 275's kinda make me cry though. Did a gear box mount from flat changing :D
bahaha... flat changing. doesnt the porshe have a poor engagement system or something u wer telling me.
i cant wait to leave 4 big black skid marks outside ur house and down ur street :(
i wanna watch :no:
same mate same!
with joshwa's help it could be even earleir than anyone thinks! :no::D
ohh. joshwa fetching parts..
i worked 11hours today and spent 15hours at friggen work. casual rates FTW
They do, if you keep that in mind and dont try and force it in it's no different. Just what your used to, drive it like a GTR box and it'll be biting back, spend some time getting used to teh goofy build and it's perfect
Nice, cant wait to see it finished... I remember the day you got it...
I remember talking you or helped in talking you into swapping it for the S2... :D
haha i remember that too!
im hating u for it now though. i coulda had a 700bhp 33 gtst by now :(
i wanna watch :)
nah im good at sourcing parts, he's helping me write a little letter
morning all forum died again earlier?
morning :w00t:
yeh it did, what else is new though lol
yeh man looks schmick
im pretty sure andy's got a similar setup.
it'll be capped around 300kw though with the std manifold
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
