Can I ask, and answer honestlly...
Would you modify a brand new car???
Considering you have a perfectlly good car and all its gonna do is burn more fuel if you f**k with it...?
Also you would loose factory warranty and it could end up being a 50k+ mistake???
Would you honestlly modify???
Cause i think im talking myself out of it, that and id be killed by the mrs for touching another car...
Pussy!
also like to say thankyou to optus for putting ther technical service team in friggen india. or should i say hire a bunch of the over ther to take my call. i got up the lady telling me it was my modema nd router problem wher it says my optus account has been suspended. spoke to the manager after 20mins of asking for him and shouting at her. and in the end i entered my credit card details in again and redid the account. i just needed my damn password which was suprisingly the friggen alphabet!
thanks optus. U FAIL
who should i change my internet account over to. i want 20GB p/month at least and no slow shit connection for cheap as possible
and cheers shane for sending me the sms sayin bank is cancelled. stupid rain. looked out the window at 3.30 and it was pouring. my mate checked the site told me cancelled then shane sms. cheers bud.
when u guys headin out next time.?
3000th page!!
uh col since when do cars use more fuel when u put a free flowing exhaust on?
and hell i would modify the new GTR
40 PPP n00b :ph34r:
no worries mate :nyaanyaa:
it was wednesday, but not sure now
3000 pages of utter shite all in the one place. Congratulations to all those involved!! :)
40 PPP n00b :)
Oh the irony..........
el oh el
computer is giving me the shits: Anyone know why all of a sudden when i save a file it defaults back to the "documents" folder rather than the folder you have been working in?
why its sucks is i make a document then export a pdf for client approval and every time i make a pdf it defaults back to documents folder so you need to navigate back through the folders to the client folder your working on?
make sense?
its shit and takes up my valuable time.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
