does anyone know if the JJR Hyperflow exhaust or the x-force one are any good?
I,ve used xforce in the past and they are fine. A tad louder than some but a great free flowing exhaust nonetheless.
But your right, cars are far safer, hecne you have to ride not only safelly yourself but keep an eye on everyone else on the road...
Yep i'll vouch for that was riding on a dead straight road only myself and 1 car coming the other way, wasn't doing anything stupid and she turned straight into me, had no time to do a thing. Went flying 20metres was very lucky i wasn't badly injured or killed. Been sitting on my ass for the last 2 weeks going to the doctors everyday to get my leg redressed, i think i'm gonna give the bike away for a while to many moron's on the roads, not that i have a choice bike's a ride off.
Hate to burst your bubble Shane. Non V-spec GTR's already have a 2 way.
must be pretty lose then...almost as loose as josh's mum's c...:P
on a side note - theyre open diff fronts right? ur thoughts of 1.5way front 2way rear? (ATS carbon)
Hey hey Joshwa
Whats doing?
Spent some time up your way over xmas, was nice to break out the jet ski again!!!
Just looking at cars forsale... About it really. That an I have a cold and feel like shit lol.
Hahah.. Yeh need to watch out for the DPI wankers.. Know them all too well.
The fronts are open and the rears are set a little loose to allow for it being a road car. But at least they can be shimmed up, unlike the V-spec crap which is considered economically unrepairable when they crap out (like on most V-specs that do some serious track) so they then have to find a replacement and most go for a non V-spec because they are repairable and adjustable. So not sure how that's crap Josh :D
Shane, just reshim the rear and get a decent one way front. 1.5 is a bit much on the front.
The fronts are open and the rears are set a little loose to allow for it being a road car. But at least they can be shimmed up, unlike the V-spec crap which is considered economically unrepairable when they crap out (like on most V-specs that do some serious track) so they then have to find a replacement and most go for a non V-spec because they are repairable and adjustable. So not sure how that's crap Josh :P
Not so much crap as such, just more devo’d, after spending all night putting a GTR rear cradle into a gtst then to have it still single peel haha :laughing-smiley-014:
Nothing a few hours and some shims didn't fix though
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
