big brakes are cool....unless you buy D2s then you just look like a tight ass, awesome 8 pots, too bad each pot is so small it is barely visible to the naked eye
also there was the write up on here about how the mounting bracket snapped at a trackday and the dudes caliper fell off
mmm quality, compared to stock I would consider the D2s to be a downgrade
Gittouttatown Goofrey, Everyone knows its far more important how it looks as to how it performs. :/
Which is exactly why I drive a Midnight Purple GTR33 with Bronze TE37s :)
Except when I'm whoring in a Lambo/Porka/Fezza CS.
Food, fashion, entertainment, lifestyle. That is all
u forgot the bitches mang, its all about the bitches!
but then there are others like duncan (i think, or is it beer baron?) that run them on their race cars, and the bloke overseas thats done the massive write up, and have said they are awesome
Ooh, someone, somewhere did a write up!
Sounds like proof to me.
Yeah I think Tacker gave them a shot.
BTW on a side note, if you do make a mod to brakes like a setup change, FFS get them engineered or you could void all insurance. CTP, comprehensive, the lot. It would be considered a major change and would need some calcs to be done and a braking test.
Hey Josh
You have not heard the ad on the radio at the moment
"Just left school and you holding the keys to a brand new red ferrari, you smell the leather blah blah blah,
then you drive it and brake something parking it...
There is no future in being a parking attendant, enrol now into blah blah blah"
See there is a way you can drive hot cars all day, Ferris Bueller stylez :D
Trust me.... Im a professional...
ARRRRRHHHHHHHH
HAHAHAHHAHAHA, ARHHHHHH
Hey Josh
HAHAHAHA! I haven’t heard that one yet, must be a Brisbane station. I hate parking attendants, the f**kers always want the 911 keys “in case they need to move cars around” when I park in the CBD.
Im like that’s a load of shit, just give me a park where you won’t need to move it
yes, thats right, you are a dickhead
Some of the reviews HERE and HERE. Tacker hardly goes easy on them too, running full slicks in 40+ degree heat. The v8 supertaxis even have to change their brake setup when they run there due to the heat. For the price they look like a decent kit.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
