Most people haven't even heard of Skype it's still so new. But for us former executive management types it's perfect. Calls are cheap as well to mobiles and landlines. I just had a half hour video call with a mate in Melbourne. Free as an VOIP phone with video. I even have it on my E65 through an app called Fring that allows me to take VOIP calls in a wireless node like I have at home.
IM on the other hand is complete rubbish and I shudder at the number of people that have had virus infections through it. And I remember IM and ICQ from when I was in Uni in 96.
But if cool means using the stuff all the semi-IT literates use then yep, I must be uncool. :D
Your explanations are far too long for whore town.
Let me drive some cool euro shit. I'll give you hugs/money :laugh:
SHAN Anna and i need a flatmate we should be living at Mt Gravatt east soon in a nice 3 bedroom town house with pool, 25 minutes to the city by bus and 15-20minutes drive to Logan
ooer, lock up garage? I dunno about sharing tho... don't wanna walk in on your sexy times :)
Main reason I don't like skype is that the protocol's insecure, and even if you're not using the program, data is relayed thru your PC for other people's call (which is how the protocol works... link all the nodes that give the quickest ping and go thru them)... which when your upload and download limits are tight, don't work well in my favour.
Otherwise for the rates n stuff I'd be all over it.
I should probably install it, and only run it when I need to make a call :P
ooer, lock up garage? I dunno about sharing tho... don't wanna walk in on your sexy times :laugh:
I should probably install it, and only run it when I need to make a call :)
Ya there is a lock up garage, plus the complex has a big gate on it that you cant get out of with out a swipe card...makes stealing cars from there pretty hard :)
ooer, lock up garage? I dunno about sharing tho... don't wanna walk in on your sexy times :D
I should probably install it, and only run it when I need to make a call :D
Pfft. Of course you wanna walk in on sexy times. Andy makes most of the guys in the club go weak at the knees. :P
Shan, you may as well cut you wedding veg out and get a Mac if your that limp about security mate :)
/short response to keep everyones attention span/
Bahahahah he's never stepped foot inside Family, but he was a frequenter at the Beat about 8 months back, AND I have witnessed him dance to Craig David. Admittedly he had swallowed quite a bit of Virgin Bourbon at the time :thumbsup:
:laughing-smiley-014:
btw, omg ur back in whoretown!
I pity the following people
Who posted in: Whoretown - Beware Of Ginger Ninjas!
Poster Posts
shanef 8143
Nismo_Boy 4577
Silver_R34_GT-T 4207
phatboi2010 3102
Keegs 2636
markimak 2384
Mr-Toy33 2331
impact_blue 2204
Bunta 2178
Col-GTSX 1983
lilmike86 1965
LIL34 1947
SMR33 1894
Konrad 1888
FineLine 1849
85URK 1314
Oblivion 1279
SLO-89 1027
Squizz 950
Mushroom 941
dano4127 814
Revhead 726
Mr Kofi Ahmed 623
Liz 608
LBR33 535
Rhinorebel 525
R33S2 492
donkey_punch 487
zaffa 471
dangerous_daveo 369
IanB 362
subzeroR33 354
Ska 325
Mud 246
AzzurrA 234
3lit3 32 220
RusH_ 217
shnaped_second 206
T04GTR 193
Devils_Advocate21 174
666DAN 164
EnGaGe 161
predator 158
ZENNON 155
Eug 142
Slide 135
Hell Fire 135
Nexus9 135
pear 127
Oz 122
S04R3R 120
SmoothLine 104
Strik3r 102
DOU33 90
ze_flexy_1 86
frankxinyu 85
r33_racer 83
Demoniak 77
d00dz 77
Wagamama 64
ZOR 64
BLiNKsTaR 61
*..KITAS..* 60
AZN25T 57
Jdfnq 57
K N P 56
D_I_F 53
Noy 51
chaos 47
GTSTGIRL 47
Einstein 43
myR32 41
prego 40
aphid 40
NismoGirl 40
choyda 38
RetardedMonkey 36
Ed G 36
GTRgeoff 36
Ivonin 35
spilmer 34
ookami 34
VL-TRBO-RB20 32
GTR_KILLA_VC 32
n15m0 30
N1GTR 30
SAM112 28
sik_vs 26
mrbenno 26
jaqule 24
Lazy-Bastard 23
sloazr33 23
D-limo 22
silverbulletR33 21
miss_petepie 21
Sl!m 18
gts25t4door 17
jibbz 17
Rednisr31 17
sweetr33 16
Crimpage 16
NFAA32 16
BoostdR32 15
booosted33 15
OBNXSH 15
sh@un 15
RB_turbo_bitch 15
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
