pics up tonight. this car is fkn amazing. bitch of a thing to drive (Twin plate clutch + short shift kit == rough), but its soooo worth it :)
the twin plate and short shifter in my old car were the best mods it had! you will get used to it..and do you revmatch on down shifts?? That makes it alot smoother
atm i usually just cheat.. break for a bit, then blip the throttle while i change then start breaking again - its a lot smoother when i do that. gonna start training myself to heel toe. im very happy.. car is just insane to drive..... atm ive only been game to use low boost (~450awhp).. and that still feels too fast... high boost is ~ 550awhp.. gonna be taking it easy for next few weeks.... i still get speed giggles after giving it a squirt.. its just insane.
STFU and show us some pics. :)
will take pics when i get home this avo.. heading home early so 3-3.30pm will have some pics up.
edit: http://www.skylinesaustralia.com/forums/Fu...Gt-t201722.html - pics from the sale post.
dude that is sooooooooooooooooooooooooooooooo nice
ihateu now gtfo and drive that shit
well, if you had foot to the floor from a 2500rpm start, it prob wont really hit boost till about 4000rpm.. full before 5000, but its not designed to be driven down low.. anything below 2000rpm and the car doesnt like it. im usually changing gears at ~3500 to drive smoothly. if you started off at 3500-4000 it still takes a couple of seconds to spool up, but its not too bad for a single.. T04Z is a good turbo.
btw when i say full, i mean low boost setting only.. high boost will obviously add a bit more spool time.. car revs out to 8800.. and only thing stopping it from going further is the crank.. forged crank and it would rev to 10k prob.
current list of things to do:
- raise car ~15mm (currently front lip sits 90mm off ground)
- plum back screamer pipe and add a cat (well.. something that looks like a cat anyway :))
- touch up tune @ Matt Spry's
- QR racedays :)
- plum back screamer pipe and add a cat (well.. something that looks like a cat anyway :P)
- QR racedays :)
how good are screamers :)
you dont happen to know who did the roadworthy on this car do you?? Sounds like they may be useful to me over the next few weeks!
sweet looking car!
Ditto :(
remember to always double the clutch!!!!!
"You amost had me, you never had me, you never had your car"
Sorry, F&F quote time again... :D
Car looks nice, few questions but
Does it have a back seat or rear interia or was it bought with the cage in and the mod plate for the cage???
Hey whats down on the mod plate in terms of codes??? Cause i notice there is no drivers airbag either ands it said it was a series 3 right...???
So I assume that the mod plate is for the 2 seater mod (rollcage in other words) and for the removal of the air bag from the drivers side.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
