SO........
WHAT HAS EVERY ONE BEEN UP TO???
WHAT YOU DOIN THESE DAYS JOSH???
SHANE??? MISS ME???
SOOO BORED.......
not another huge f**king post ;)
P.S no :)
Insurance......
what a pain in the ass........
Had this old couple run up my ass about 5 weeks ago.......
only today do they send out an inspector to look at my bike......
farking slow karntsss......
lucky i still have the sill to drive.....
any one know if i can claim a new helmet in with the accedent seeing as i have to buy a new one due to landing on my head.....
no wonder the helmets f**ked :D
did ya ring main roads to report a large pothole in the road too? :P
I have roughly a 60 – 70% STOCK R33 clutch, with a machined flywheel that’s only been in the car a few days.
But I want some coin for it…
hmmm breaking my balls man breaking my balls lol
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
