>_<
What cruise (if Any) Are you going on this weekend MR???
wasn't planning on going on any cruises this weekend....I assume you are referring to HardTuned.Net @ the other Skyline Cruise 4 2008.
I was thinking of saving my clutch for Willowbank on the 20th......but then again if I wake up on sun and feel like a cruise I'll hop on board the Byron Bay trip!
Haha Fair enough!
Yeah i only just seen the drag day yesterday! I might come out for a looksee!
I've got a few Non skyline friends going on the Hardtuned cruise, so i'll prob tag along on that one.
Although Byron is a great drive!
Haha Fair enough!
The hardTuned.Net one just sounds far too busy.... 500 cars??
if a wrx or evo was doing 100 k's and drove onto a ramp on the back of a moving truck-what would happen when the front wheels stop moving but the back ones are still doing 100???????
Bye bye centre diff :)
I got mine from JustJap http://justjap.com/store/home.php?cat=282 theres about 4 on the page in amoungst actual car seats. My one is 299 but there are some cheaper ones. No doubt can get them cheaper from elsewhere anyway though.
I also have the 'Logitech G25 Racing Wheel' so it's a nice set up here :D
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
