Anyone wanta buy my ZX6R???
Its going for trade in on Saturday unless someone takes it off my hands sooner...
Have signed paperwork at $7600 trade...
So if you want it, obviouslly it can be your for that money, as the dealership is only going to turn around and sell it for 10k+
Which is farkin cheap for an 04 with less than 17k on the clock... ;)
The cheapest on bikesales.com.au in similar condition is $10,990
Just thought id post a quick comment as its no skin off my nose if no one wants it...
Guys,
I went to buy a rear strut brace and was sold a front instead, so before I take it back is anyone interested in a polished JIC front strut brace to suit an R33. I will sell it for what i paid for it ($220) if not I will take it back and get them to provide the correct one.
Cheers
Mushroom
damo i thought i told ya not to strip man your scaring the kids for gods sake!!
P.S hows the batt?? and whens the sexy pic shoot tell aliesha no luck wit da modlez
i sowwi but i know the kids like it :P
battery seems fine still need to go to ECC to get all wiring checked and get my Power FC put in :blink:
and the sexy pic shoot with aliesha will have to wait as she is in syd and models you say :blink: and sif you cant get models
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
