Tristan: when you getting the 180? Thinking of the coast sometime next week since I have the whole week off and Dan's gonna be around too.
bro some more work is starting tonight, and more tomorrow :)
as for being ready in a week - unsure, as the new motor needs to be run in and put on the dyno to check out timing n shit - so im probs leaning more towards no then yes
I got a Clear timing belt cover, turbo brakes and some Nissan Skyline floor mats, weeee :) (My 34's Chrissy Presents) Merry Xmas everyone ... Can't wait til the count down to 2010 :D
clear timing belt cover is porn! are your brakes in yet?
you coming around tonight?
Brakes - Not in yet, Will be before my cruise :)
Tonight - Should be hun, not 100% sure what is happening?
not 100% sure - i think arif and i were toying with the idea of doing a little work, having a few drinks tonight and then getting into it tomorrow
but then again, now that i think of it, arif is probs getting rolled today at work - so might be tired
ill probs give one of you cats a buzz when i get back to brizzzzzzzy, like a boss
ps keen on brakes :D
ps keen on brakes :)
Oh sweet, I am cool with whatever :)
Can't wait to get it all finished !!!!
Will talk to you later :D
Oh your not in Brissy? Seeing the Parentals?
yeeh im down the coast with the parentals - rhyso and i are probs heading up around 6/7ish depending
and yeeh rhys is keen on getting his wodka on with you hahahaha
aait well ill give you a holla later this arve :)
Brandon - Where is my invite :D
Of course you're invited. Its opened to all. I thought since Dan has always been coming up on Thursday nights, we might just go to the coast for once. Anyway its just a suggestion. No idea how many people will be real keen.
Speaking of brakes, I just noticed today that my back right hand side brake isn't working. It's not pushing the pads onto the rotor. Where is a good place to go to get brakes checked ?
brakes are overrated
Any normal mechanic could do it.
And now onto my news... got a 2t tradequip trolley for xmas... so I've spent this arvo taking my front bar off hahahaha (first time ever) god damnit... took me a while to figure out how the reo bar comes out.... D'OH
And now the sanding begins...
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
