sorry to bring up somethign from this morning but i think these look great
18 x 10 + 18
these sold end of last year for under 2.5k
oh thnks bro, i was searchin all over for those, i saw them a while back the guy was sellin the car, then ended up sellin them lenso D1R's
thnks alot BIG MT.
thnks alot BIG MT.
no worries mate,
just don't want to see you end up rolling on a set of rotas :D
dude if you like the look of rotas go for it - they will be more than fine for a street car
its only if you are tracking them and smashing them on ripple strips or something then they will be much more likely to break than a decent forged rim
yeh, my car wont relly ever see track time etc, i just dont think its worth spending 4 grand on the volks, if i can get the same look, infact even better since theyr more concave they give a thicker look, thanks for opinion martin :D
bro why do you hate ROTAs so much? did u have them on your car or something? or is it just coz u see them as fakes or copies? just wondering.
Just a matter of personal taste. I think I am just a brand whore...
anyone here from mission beach? Been on holidays for a week here. Its bloody raining, stupid rainforest. Hopefully it passes for tonight.
Bad luck mate. Its been shit for the past week as well. We were gonna have a Gold Coast Trip 2 days ago until I got food poisoning...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
