FBT = fringe benefit tax
You have to do a minimum of 25,000km per annum to slip under the 11% tax threshold on a leased car...
In short if you do 24,600km for example in a year you then have to pay 14.5% tax for the value of the vehicle...
So in my case that's a difference of approx $2000
Meaning if I hit my km's target I pay nothing more, if I don't hit the target I have to pay $2000 extra tax...
Ive never had a problem doing 25k a year... However I just came back from 7 weeks annual leave an did not drive the car at all while away...
So I have a compiled problem once I returned to work... So I needed 2500km on it ASAP...
Now I am within 800km of the disposal target with 9 days to do it... So 100km a day and i'm all sweet now...
Seriously? 25000ks?
I did 15000ks in the past 4months.
I usually tend to avg about 4000ks/month give or take.
I should get a lease vehicle for work. =D
I like claiming the maxima\, i mean skyline of tax though. hmm..
Edit: Woot! 50th post!
Edited by Tony350
my 3 year old nephew does 4 weetbix...
i eat bacon... nuf said
Eh, its one of my 5 meals a day, heavy breakie makes for a sluggish start
I'm sorry.......
I just don't like soccer!!
There, I said it :verymad:
So boring
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
