eBay u say.... Nope have no interest in that as it makes me poor lol
Yeah they basically double-dip, force prices up while my whole ethos is supplying quality equipment at half the price, they really don't help me with their fees and poor support....oh and the biggest farse, they don't let me list half of my equipment as it is in breach of their poor blanket-ban policies.
Sure is, getting back to my roots....won't be on ebay for long though, currently getting the proper website built and taking on the big boys in the industry :D
I'm fascinated by the whole ebay/earning a decent salary on there. Some of the legit ebay business's that submit earnings to the ATO etc that come up for sale are mind blowing.
Tough gig to get off the ground though
depends on what you are selling. I am considering getting into it myself in a big way. i have enough unique items already at my disposal just neec to list them.
i do agree with the limitations though. list 60 items and you see half if you are lucky.
I have read that, Ebay fee's, paypal fee's, account limitations blah blah blah. But I suppose just like a "real" business you have everyone taking a cut from your profit.
Finding the next "big thing" is the hardest haha! If it was easy we'd all be doing it.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
