Ooh hai nick, sounds like you're bored.
Yep, couldn't sleep properly so went into work early... Bad idea now I'm bored lol. On the plus side, the sun is now up so woohooo
Frostilicus, you've been at work all night? Fark that
good stuff.....include sext of hot bishes too!
Hmm depends where I end up tonight, three oportunities on the cards ;)
Well two, but one has been expressed as a form of interest for tonight/tomorow
What y!?
Answers :verymad:
.... Also work is slow so ill whore, by myself, tony? micheal?.... Old Man?
LUUUUUUKE!!! :/
Agreed!
That sucks :( good lucksky
DA farq?
I want to be bored!!! work....
Essentially had enough. Didn't feel that everyone was working towards the same agenda and just got fed up.
Last Friday was the first time I got to go out with a non-SAU person and that was just with a guy from work!
Just came down to I've put in too much for no reward.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
