Woo! And I'm buying him a present Tony, not you ha ha also how good is he at reading analogue clocks?
And Natro, I'll buy you a present for your birthday right now ALL my money is going towards groceries and my 21st ring.
Haha ill hold you to that, 12 September :P
What exactly is a 21st ring?
Its a ring that you give as a gift on your 21st birthday.....not too fond of rings as the last one I got = marriage
Know the feeling. Wasn't married but close enough to it. Farkn men, takes house and cats, leaves me with the kid :/
Was a pretty ring though
My brother and I had a couple of glasses each and then he left it here. We actually bought our Managing Director a bottle of johnnie walker swing to commemorate 20 years in the industry.
Was very yummy. Would have gone perfect with your marmalade ham
Wow. Looks like you got wrong end of the stick. Usually it's the other way around (no offense)
But at least you have a wonderful toddler.
Nice. Il throw up a pic of my collection. I also have the JW Swing :)
Ask and y'all shall receive :D
Highland Park - my fav and the best spirit in the world (the title for the 18yo HP) just excellent
HP 25 YO (VERY EXPENSIVE!!!) Recently scored 100 points (a whisky drinkers whisky they say but at 47.5% proof its a real knock out :cool: )
My current taste buds prefer Glenfiddich - just a unique whiksy and that Malt Master is pure sex in your mouth
also have the JW collection - not a fan of blends (good with coke cola or lemonade)
one for Tony - that XO I recently opened is sensational after a nice dinner
I have plenty more that will do for now
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
