Yes, every 5th, it's a nice regular number, makes it easy to know when the next is with minimal mathematical knowledge.
And make sure it's at the top of the page also.
Thanks.
hard to make it at the top of the page mate.
Yes update ants stay on it, and #@Cadmoon its the same silver celica that was at happy laps at qr parked up near the canteen.
#@Ants it blew up about 5-7ks from my house, took us probley 40 minutes ish to walk home.
good......you need to do some cardio anyways
Ants.... Looks like you have no choice here
wat u mean? there's always a choice
One page till the update ants better get on it :P
nope see below
The people have spoken, every 5th page.
Anyway, i'm falling asleep, work is that thrilling, need to go home and finish the 34
wow!!! talkin bout peer pressure and expectations from da lot of ya!
technically because the first inaugural update was done on page 3514 the next one is schedule to be on 3519 otherwise there will f@rk all to summarise.
Because I can't be trusted with such epic and colossal responsibility, I recommend we circulate amongst the regulars that post here and will I implicate the following:
Ants - page 3519
Tony- page 3524
Nick - page 3529
Martin - page 3534
Scott - page 3539
Chris - page 3544
Andrew - page 3549 and so on..........
otherwise i'm not doing it.................................
Edited by Ants
4-9 is stupid numbers... And don't drag me into this this is your thing with Steve lol
Also just face stalked zeke muhahaha :devil:
I shall implicate the lot of ya muhahaha LOL......
cool that means where not doing it :P
Edited by Ants
Falling asleep? It's like what 1:20!
I spend most nights til 12-1am wrapping shit, give me a break...
Clothes are expensive. Looking at buying a few pieces and here's the breakdown:
Shoes/Boots - ~$250-$300
Watch - $400
Jeans - $150
Brands?
nope see below
Ants - page 3519
Tony- page 3524
Nick - page 3529
Martin - page 3534
Scott - page 3539
Chris - page 3544
Bah, you started this whole thing, and you're doing it wrong, it's every 5th page, and should be starting from 3515, 3520, 3525, 3530... and so on.
And you missed your deadline on this one, so you have 5 pages to redeem yourself on 3520 with a double recap on the last 10 pages
Brands?
lol......I feel so ashamed for letting u guys down :blush:
bad ants, bad ants :spank:
yes it has.......now to get you up to speed:
Cowdy going camping and upside down 4WDriven with MsCowdy
Nick - getting smashed as usual - and blowing his diff in his Celica (loved to know how?)
Chris - ranting about how many more collectibles he can steal
Tony - changing his avatar from R2D2 Heinenken Kegg to fake autographed Suzuka Circuit
V8skylineMan- still waiting for parts
Martin - wondering where Tony is
Scott - has very delicate hands
Chantalle - busy yelling at Tony
Luke - complaining about his health
Me - just chuggin along
I don't steal any of my collectibles. While talking about collectibles had another 2 model cars show up the other day.
Fell off the back of a truck outside your house randomly?
Kinky... Nick likes this...
No breaks, mao diddy mao! *cracks whip*
As demonstrated by this ^
good......you need to do some cardio any ways
nope see below
Ants - page 3519
Tony- page 3524
Nick - page 3529
Martin - page 3534
Scott - page 3539
Chris - page 3544
If someone does mine I will owe them one reach around
Brands?
Watch is a Bulova piece, jeans are CK and shoes are either Boss or Julius Marlow - if I choose to keep it cheaper :)
and another 2 gone awol :D (better start counting 'em Chris)
maybe should start calling him 'Kinky Nick' :devil:
Again leave me out of your lovers quarrel
... Unless, well you know :3some:
and as demonstrated by this ^
I'm a fan of Julius Marlow shoes. The uppers last really well and they have been easy to get resoled as hospitality tends to demolish the soles of shoes between the alcohol and very high milage they get put through.
Although my current work shoes are Converse One Stars :)
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
