"Holidays 2013" so I'd say November.
No backwards compatibility. Not sure why people actually care about this feature. It's not like your old machine suddenly disappears if you buy a new one, and besides the PS2 no machine has ever really done backwards compatibility anyway. The 360 had limited compatibility that was gimped to say the least. I'd rather a machine with no backwards compatibility then gimp a new machine to make it work with old games.
In the plus side, PSN will be doing digital distribution of 'critically acclaimed' PS1, PS2 and PS3 games :)
my ps3 plays 1, 2 and 3 games.
means I only have to have the 1 console plugged in.
and I do play 1 and 2 games on it.
not often, but thats the point.
dont play them enough to have the dedicated console plugged in permanently.
and cbf hooking it all up when I do just want to throw it on.
and you might be able to download it, bit whats the point if I already own it?
Understated? Market share? yes. Critical acclaim? Nope.
Yamazaki has taken 1st at the World Whisky Awards 5 years running now for best single malt and Hibiki has picked it up 4 out of the last 5 years for blended malts.
And yet the Japanese drink their whisky as Mizuwara - 2 parts water to one part whisky in a highball with LOTS of ice.
The 25 is almost flawless. Perfect balance with lovely sweetness off the grains but intense wood flavours from the maturation. Hint of smoke and a touch of peat but not a lot. Mainly dried fruits but at the spicier end of things.
Yep - Japanese whisky produce high quality stuff and have been for quiet some time now. But even the 12yo yamazaki is rather pricy at $85 a bottle (or something like that)
I never put ice - water only if required (usually with the younger whiksies - anything over 18 - usually very minimal to open it up)
or you could pay a smidgen more and buy Glenfiddich 18 year old where a single malt is also aged in the same mix of barrels and using the same process as the Master.
How you get away with charging nearly the same for a 12 year old as an 18 year old when they are aged in an almost identical process is unknown to me... That is some clever marketing.
Marketing depts justifying their existence - very well mind you
I think that Japanese whiskies are way understated from a market share point of view. They are if not already better than some scotch whiskies.
Have 12 yo Yamazaki - very nice - lots of sherry with hints of caramel and sultanas
Yamazaki is beautiful! It's great that it's understated- keeps cost down. :D
I have small ice and big ice. I use ice if it's a warm day and then it's only one small cube to chill a little.
A touch of water opens it up so much more though.
Keen as to get it - just hard to procure in Oz :unsure:
its color is so deep (better fkn not have any coloring in it :glare: ) - read reviews about it even think it was nominated the best SM in the world over 20yo)
Pphhhh........blends - can't drink blends (been many years since I have)
this is a big factor Tony.
Try your whisky in a Glencairn glass (no ice ok) and add a drop of water, cover it up (with a watch glass cover) and leave for 20mins.....then taste it and thank me later.
Edited by Ants
They do have some awesome models,
Sadly too expensive of a hobby for me, the real car costs me enough to manage as it is...
Yep, heard that. the one above is just standard R32 GTR model and cost me around $89 + $20 postage IIRC.
I have the R32 VSPECII at home also in crystal white but costs me even more, which is why I'm not buying anymore......for now.
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
