I could do that... or I could take my car with me and try it out on the lovely new range they just finished on my way to where I am going... I am yet to see the abomination and I am looking forward to it.
You made 270rwkw, u should kill me lol
281, Yeah it should but until next drag day it will stay as a should...unless I can make it to happy laps then we can put it to the test.
By next drag day I will be making alot more than 280rwkw ;)
Yet you will still be smoking the wheels and not going anywhere.
Get your current power to the ground first
Nick if you have coilovers already set the fronts to a few clicks from the hardest setting and the rears to a few clicks from the softest setting, this is the best you can do in a short time.
Also dont drive around too much like that, your braking distances will be terrible as the front will compress under braking and hop along the road, effectively shortening the amount of road you have to stop on.
Good, only input I've seen since you've been here is whinging anyway. :wave:
you are such a tard. Would you like a jump to conclusions board game as a parting gift?
the web host of the old forums is sh1thouse and i setup a redirect but it seem to redirect "all" http requests. I am working with them to resolve it.
Yep we are straight up all shit blokes. Should be shot. How is your tin foil hat dave?
http://www.skylinesaustralia.com/forums/topic/424059-voting-on-forum-relocation-to-the-mothersite/#entry6893404
Well, that escalated quickly...
You guys are in charge... I just felt some idea of what was going on would have been nice...
And your keyboard warrior status is intact. Face to face, I think you will all fold like Martin's condom...
  • Like 1
Dont make me post a Black Eyed Peas where is the love reference,
Well there it is, look what you guys reduced me to
They don't make water hot enough to make you clean now Andy
Keyboard warrior ftw! :D
I'd argue the last part of that statement purely on principle.
I will tell you to your face. Where are you going with this line of reasoning?
You cannot come onto a public forum, make accusations and threats of leaving and expect nothing in return. seriously Dave. I had higher expectations from you of all people. You have sat in the hot seat before and know all to well how best intentions by any exec can be misunderstood at times and often when a "QUESTION" is asked a reasonable and logical answer can be found.
Or are you just being an attention whore?
That did escalate quite quickly. There has been the constant assumption that we're power-hungry dictators trying to reap all the benefits for ourselves.
I for one know that the guys on the exec have worked bloody hard to get us to where we are. The club is moving at a great pace and there is a lot on offer for the members. We have regular events and outings for our members, that we as the exec are almost obligated to attend. We attend these events in the minimal spare time that we have. Since joining the exec, I haven't had the time to even see good friends of mine.
So this constant bickering from you is enough. If you think that you could do a better job, nominate yourself for the role when the time comes - should be end of July.
And yes, I would say this to your face but it's not like you actually attend any events anyway. You are essentially harping on about something that doesn't even effect you.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
